Results 1 to 13 of 13
Thread: l67 charger differences
    VT spac super6
    Nov 2008
    Riverton sa
    Default l67 charger differences
    Okay so iv got a vt super6...
    soon ill be looking for a new charger...
    to the point iv been told that the newer versions of the l67 had a watercooled charger..
    for instance on the vt's theres water jackets leading to the charger... but are blocked off on the charger?
    any one know more about this all??
    cheers
    VS l67 statesman
    Dec 2008
    Ive read the water jackets were used on earlier US L67 versions,but I dont know how accurate that is
    VT spac super6
    Nov 2008
    Riverton sa
    if theyre there id love to use them!
    anyone with a l67 knows how friggin hot the charger gets just normal running!
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    HARVZ-6, they dont get that hot if you have good coolant! Mind you, i still wouldn't go touching it after it's been running! But still not as hot as if you didn't have enough coolant, or leaking coolant
    VT spac super6
    Nov 2008
    Riverton sa
    I mean the charger itself baha
    motor sits on 83degrees all day =D
    coolant wont change how hot the charger is seeing as theres no coolant running through it!
    VY SII HBD Calais L67
    Dec 2006
    No need to upgrade the M90 mate. There are a bunch of affordable mods to do to it that will vastly increase it's efficiency (read lower heat output) and still make it a little torque monster.
    IMO if you're doing away with the M90 it would be better to go turbo. M90 has mean bottom end and where it runs out the GT35/40R kicks in
    VYII Calais L67
    VT spac super6
    Nov 2008
    Riverton sa
    im not worried about it... i just know that the water gallerys are blocked off..
    since im replacing the charger soon because its nearly f**ked wanted to know if there is a new version where these gallerys are open
    despite turbo being a wanted option.. to expensive on 1st year apprentice rates lol
    it already costs me 100bucks a week in fuel as is
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Those water passages in the lower inlet manifold are for feeding water up and through the throttle body adapter on US versions.
    They can't be used on the Aussie version beacause of the bend passing over the holes where as in the US versions they feed up around the inlet to the SC.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    VT spac super6
    Nov 2008
    Riverton sa
    Dec 2006
    You say your charger is dying? This is very very rare even on high boost set ups. What's the symptoms?
    VYII Calais L67
    VS l67 statesman
    Dec 2008
    Did you kill your rotors by disconecting the boost activater and running constant boost?
    VT spac super6
    Nov 2008
    Riverton sa
    seeing as the charger has done 297000thousand ks lmao
    the linish on the rotors has worn off.. causing them to knock together so the charger "rattles".. i know the linish is gone because i rebuilt it with new bearings 30thousand ks ago..
    symptoms are- rattles, down at 8psi tops on a cold night 7 normal.. running a 10psi pully on yellaterra snout.. when you snap the throttle open it only hits 4-5psi at first and slowly increases with rev.. only way i get 7-8psi is if i hold it out to nearly the limiter in 2nd etc
    VT spac super6
    Nov 2008
    Riverton sa
    and no i didnt make it run boost constantly.. since i get 500ks to a tank and do 500 a week to get to work no way do i want worse fuel economy lol
  1. VS BCM Low & Mid differences?
    By Shambo in forum Electrical Wiring / Questions
    Last Post: 24-01-2009, 04:40 PM
  2. VP BT1 5L - Differences ??
    By projectaero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-01-2009, 03:32 PM
  3. V8 differences
    By zohpm in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-09-2007, 08:45 PM
  4. VY SS and VZ SS differences
    By hothouse vy s in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-09-2006, 12:33 AM
  5. V8 differences
    By bangers in forum General
    Last Post: 20-06-2006, 02:12 PM
