Results 1 to 6 of 6
Thread: VX clutch problems. PLEASE HELP!!
    Vx S pack S2
    Mar 2009
    Unhappy VX clutch problems. PLEASE HELP!!
    Hey guys im really hoping someone can help!!
    I have had my vx manual s pack for about a year now, (its done 180,000) never had any troubles at all with it! my clutch is getting very heavy which make me think i need it a new clutch which is simple but its not just that, whenever i put the clutch in to change gears the revs go up by about 400-600 revs. the only exception to this is when i put it in gear take my foot of the accelerator for about 2-3 seconds and then there is a small grab in the engine kinda like the brakes have been put on slightly or like slight engine braking, if i put the clutch in while its doing this the clutch works normal and the revs drop immediantly! even sitting in nuetrel just iddling the car will sit on 1-100-1300 revs for probably 10 seconds before it calms down to a normal idle! CAN ANYONE PLEASE HELP ITS DRIVING ME INSANE!
    thanks guys
    VX S S2 Manual
    Oct 2007
    my car does the exact same thing, although not as badly, its on 180,000 to
    Each time I go to change gears it does this little rev like i have left my foot on the pedal (i havnt because I became paranoid that i was so took notice)
    I just a little rev of 200-300 like you say.
    Would lvoe to know the answer also, my clutch was replaced a year ago.
    Vx S pack S2
    Mar 2009
    yeah its been getting worse and worse! let me know if ya find out!! cheers mate
    V8 WK Caprice + VK berlina
    Mar 2008
    Blakeview, Adelaide
    Its normal. Its called a dual mass flywheel. The car blips the throttle automatically every time you change gear supposedly to make the gearchange smoother
    Vx S pack S2
    Mar 2009
    but it didnt do it when i got it and its gettin worse! and it still wont idle properly cos of the revs taking so long to drop???
    VE SV6 Ute
    Oct 2007
    What i have noticed in my car and a couple of my mates have the same car and the same thing happens, when your accelerating hard and hit the clutch to change gears like you would in a normal car, the revs lift a bit. But try holding the revs slightly before you change gears and see if it is as noticeable. It might just take a bit of getting used to. It does make a smooth gear change
    I dunno bout your car revving high when you stop tho...
  1. clutch problems???
    By surfindude in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-01-2011, 02:57 PM
  2. clutch problems
    By RufusŪ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2008, 09:11 AM
  3. clutch problems
    By naf33n in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-01-2007, 04:46 PM
  4. clutch problems !!!!
    By stevenwilson in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-08-2006, 05:30 PM
  5. Clutch problems
    Last Post: 23-05-2005, 09:29 AM
