Results 1 to 22 of 22
Thread: Air bag light staying on. help?
    Default Air bag light staying on. help?
    Hey all, got in my car after work 2day and out of the blue the air bag light comes on, so i took it straight to my local holden in hope that sum1 would have a quick look at it but they said they cant have a look until tuesday. I kinda want an answer before then.
    Has any1 had this happen before? n how can it be fixed? or is taking it to holden my only option? Cheers
    1999 VT II ACCAIM & 2002 VX II S
    Apr 2008
    invercargill NZ
    hiya dude..mine came on not long ago..and trust me holden are your best bet..they checked for fault codes.but nothing showed up.they cleared it.and been sweet ever since...could be a number of things..so holden the best place i think..good luck.let us know what happens.
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    The SRS warning lamp will illuminate when :
    The ignition is switched ON, the SRS warning lamp will be illuminated for approximately 5 seconds to indicate the system start-up sequence. During this period the SDM performs a system wiring and self check. If no system faults are detected, the SRS warning lamp will be switched OFF.
    If communication is lost between the SDM and the instruments (for example SDM wiring harness YB190 disconnected or no BCM poll) the SRS warning lamp will be illuminated when the ignition is first switched ON, it will then be turned OFF for approximately 2 seconds and then commanded ON constantly until the fault is remedied (communication resumed) (No DTC will be set).
    If battery voltage is below 9 volts or above 20 volts the SRS warning lamp will be illuminated and remain illuminated until the problem is resolved (No DTC will be set).
    If the SRS is deployed, the SRS warning lamp will be illuminated until the problem is resolved (No DTC will be set).
    If one or more current or history Diagnostic Trouble Codes (DTC's) are detected when the ignition is switched ON, the SRS warning lamp will illuminate and remain illuminated until the DTC is cleared. Additionally, 3 seconds after the ignition is switched ON, an audible warning chime will sound.
    During an ignition cycle, if the SDM detects a current DTC, the SRS warning lamp will be illuminated. If during this cycle, the current DTC fault condition clears, a history DTC will be logged in the SDM and the SRS warning lamp will still remain illuminated.
    When TECH 2 is communicating with the SDM, the SRS warning lamp will be illuminated and the SRS will be disabled.
    You asked, you recieved!
    You can check the DTC codes yourself, or you can wait for Holden to check them with a Tech 2! Your choice. But there is details on how to do it yourself too. Check the How To section for checking error codes.
    Nov 2008
    Tullamarine, Vic
    Oh yea, forgot to mention, if it happens to be the case that the error codes have to be removed, only someone with a Tech 2 can do that!
    VT spac super6
    Nov 2008
    Riverton sa
    id guess its probly a pretensioner short..
    apparently pretty common issue.. i had the problem and got it removed with a scan tool
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    Quote Originally Posted by HARVZ-6 View Post
    same problem with mine, just took out the globe.
    nick3110's Avatar
    nick3110 is offline 2.5" Catback
    VX Berlina S2
    Nov 2008
    Quote Originally Posted by kinkbike_rider View Post
    lol.. that would fix it i suppose :P
    Nov 2007
    VT spac super6
    Nov 2008
    Riverton sa
    from what i was told it will still work fine...
    but i chose to fix it instead... plus the stupid warning beep pi**ed me off lol
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by charged-spack View Post
    does that mean if you get in2 and accident the air bags wont deploy?
    It might or it might not, you never really know. It depends on what made the light come on in the first place.
    MY RIDE
    Took it to ultratune behind my work, they checked it for me for free because we gave them a good deal on a tv they bought from us the week before haha. They said it was the seatbelt pretensioner and the part to fix it wont be available until the 25th of this month and will take another week on that to get it shipped. Then they said its going to cost me $380 to get it fixed. I called holden and they said the same deal but would do it for $330 which i thought was odd for holden to do it cheaper than someone else. So now ive got to wait a month to get the anoying light/beeping fixed.
    chromic's Avatar
    chromic is offline Donating Member
    VT V6 Sedan, VY SS sedan
    Nov 2005
    The car wont pass rego if the airbag light stays on, or if the globe was removed as the beeps will still be heard if not cleared. Unless of course the rego dude turns a blind eye.
    SMIT's Avatar
    Aug 2005
    Quote Originally Posted by chromic View Post
    lol, the guy doing my rwc told me to remove the globe.
  15. #15
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    bwahaha dodgy... how does one remove such globe? i have the same prob and need to pass a defect inspection
    Going where no late model stato/caprice has gone before.... GAME ON!!
  16. #16
    chromic's Avatar
    Nov 2005
    Cool. I did that and he asked me what I did. I said ""my mate has a tech 2 scanner" He went and checked the car and came back telling me that the globe was taken out and he wont pass the car until I fix it Rules are rules and I just have to cop it on the chin.
  17. #17
    VT 5.0 auto
    Nov 2008
    would still beep 3 times but
  18. #18
    VT spac super6
    Nov 2008
    Riverton sa
    Quote Originally Posted by daz08 View Post
    if they have a scan tool try getting the fault codes removed..
    myne was a pretensioner that set it off and cleared the code no problem since
  19. #19
    vs
    Apr 2009
    You dont need tech 2 to clear the codes any decent scan tool will be able to do it.
  20. #20
    well if thats all they need to do they didnt do it. they told me they need to take the seat out to change something and charge me $380 for it
  21. #21
    ADZWAGON is offline adz
    vt executive3.8 auto
    Feb 2009
    victoria point
    maybe try disconnecting ur battery for a few minutes then hook it back up
  22. #22
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    Disconnecting the battery wont do it as its a SRS fault and its to do with safety so the code will stay lodged...
    You can get the part yourself and pull seat out 4 bolts unplug the pre tensioner and replace the buckle then refit.. Then pop into your local dealer or who ever and get the code removed....
  1. Pwr train & oil light staying on in my vt berlina,please can someone help me
    By jagman95 in forum Electrical Wiring / Questions
    Last Post: 15-06-2010, 10:57 PM
  2. Airbag Light staying on
    By Cogs 78 in forum Electrical Wiring / Questions
    Last Post: 31-10-2008, 08:30 AM
  3. Trak off light staying on
    By offrdn in forum General
    Last Post: 12-04-2008, 08:30 AM
  4. Oil light staying on long after engine is off.
    By brydog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2006, 06:23 PM
  5. Oil Light Staying on
    By VNSV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2005, 06:31 PM
