Results 1 to 9 of 9
Thread: commododor sounds like a 4wd
    VT EX S1 3.8L
    Jan 2006
    Default commododor sounds like a 4wd
    hi ppl my car has started to make a zoom in noise when im coastin sounds much like a 4wd landcruiser iv had wheel aliment balance and still ther im thinking it could be wheel bearings or the diff any ideas would be a help
    thanks
    vt acclaim
    Mar 2009
    Scottie666's Avatar
    Scottie666 is offline Scottie
    Vt Acclaim, 1988 Vl Comm,2007 VE BERLINA
    Apr 2009
    Default my vt commodore
    hey guy's well i own a 1997 vt commodore 3.8 litre it chuggs at certain revs and now has a noise coming from the internal, i replaced the plugs and i have put new ignition leads on and it is running like a shitter, only under load. once it starts to pick up it runs perfect but then once i flatten it it splutters and then stops doing it, any suggestions. there is no water in the oil or vice verser so it can't be getting into the plugs to do this. i'm stumped, any suggestions would be great
    VH SLe/VR Wagon
    Sep 2008
    Does the sound change when its underload? Generally a diff noise will be most evedent around 80 - 100kph when off load.
    [SIGPIC][/SIGPIC]
    Scottie666's Avatar
    Apr 2009
    nah mate it isn't coming from the rear it is an internal engine noise when at idle.
    VH SLe/VR Wagon
    Sep 2008
    mate i am talking to the guy who started this post. You cant hijack someone elses post with your stories...
    [SIGPIC][/SIGPIC]
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by 6-PAC-ATTACK View Post
    thanks
    Well ,diff noise will go up or down with the speed.Easy to pick up.
    Bearing noise too but,it'll be sort of stronger then the diff,something between grounding and winding ,and if u try to make a hard left or right hand turns it will scream.
    If its a tyre noise (hope they'r not Maxxis) ,it will show up more when u slowing down from over 80-90klms.
    Good Luck.
    VT EX S1 3.8L
    Jan 2006
    thanks for your help guys ill top up the diff oil and try to pinpoint it and get back to you by the way iv got bridgstone g grid mark2 tyers but no noise untill now so i dont think its them. thanks again
    Scottie666's Avatar
    Apr 2009
    i'd be checking your rear wheel bearings mate, my right hand rear one was totaly gone. when i was drving the noise was disgusting, it sounds like something rubbing. sends vibration through the whole car. by the way sorry for stealing your thread
  1. Sounds like a wrx!
    By blacknight in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2009, 01:38 PM
  2. VP sounds to REV HIGH
    By ir8prim8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2006, 09:37 PM
  3. car engine sounds please
    By Coxy_vs in forum The Pub
    Last Post: 27-05-2006, 02:47 PM
  4. Which supercharger SOUNDS the best??
    By savage1987 in forum V6 Development And Modification
    Last Post: 02-04-2006, 11:27 PM
  5. Sounds Better... Looks Better...
    By jazza21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2004, 12:41 PM
