Results 1 to 4 of 4
Thread: coolant leaking out of thermostat housing
    VT wagon S2
    Nov 2005
    Default coolant leaking out of thermostat housing
    g'day all the other day my car over heated, ive realised the thermo fan doesnt come on, and that coolant is coming out of the top radiator hose where it goes onto the thermostat housing, any help would be great thanks all.
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Do the thermos come on when the Air-con is switched on?
    You can unplug the thermo fan and stick a multimeter on the plug coming from the car and turn the air-con on, it should read some voltage, but not sure if this can be done wiht the VT ones. If it doesnt read voltage then try replacing the thermos, it would be the easiest option rather then fault diagnosing them unless you can see something really obvious wrong.
    Replac the thermostate housing and gasket. Since your doing this and it has over heater it may be a good time to flush your system and replace thermostat and radioator hoses, replace coolant with fresh stuff (use genuine) and bleed it.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Repco make a good coolant, good quality(high glycol content per litre), cheaper price. Valvoline G05 is one of the best recognised around the world, especially the U.S. Some servos stock it.
    I'd get a pressure test done and check the water pump as well.
    vs
    Apr 2009
    You need to replace your themostat housing and top radiator hose. Check fan relay, just sawp it with the horn relay. They also breake the wires where the fan plugs in near the radiator.
  1. Thermostat Housing
    By OSL-060 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-03-2009, 07:58 PM
  2. WTD: VN Series 1 Thermostat Housing
    By Nevyn in forum Swap / Wanted to Buy / Trade
    Last Post: 05-10-2008, 05:46 PM
  3. leaking v8 thermostat housing vs/2
    By vs hay hauler in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2008, 01:20 AM
  4. Thermostat Housing.
    By eXcon in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-05-2008, 06:54 PM
  5. thermostat housing
    By 90VN55 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2006, 09:26 PM
