Results 1 to 5 of 5
Thread: Auto Transmission dropping back
    VT Acclaim
    Apr 2009
    Default Auto Transmission dropping back
    G'day,
    Recently I started commuting 100kms each way to work and even more recently my VT acclaim started after about 55km's of travel at 100kp/h went from sitting on a comfortable 2000rpm to dropping back to 3rd and sitting on 3000rpm. Which is affecting fuel economy and my lack of knowledge in this field brings me here before I get someone to look at it. Incase there is indeed a quick fix or something I can check or change. The car remains in 3rd until I exit the freeway. It will rev high in most gears then on. Once it cools down and I head home in the afternoon. About 55km's in and it does it again.
    Cheers.
    VT spac super6
    Nov 2008
    Riverton sa
    first off when it does it.. either pull over turn the car off, restart it and set off again should have over drive back.. or put it in neutral while driving quickly (turning key just one click so no steering lock) so the engine turns off restart it, put it back in drive and keep driving..
    Id say its the heat over ride that disables the torque convertor from "lock up" so your stuck in 3rd.. the heat is normaly caused by excessive slipping
    how many ks has the car done? and when was the trans last serviced?
    VT Acclaim
    Apr 2009
    186000kms on the clock. Couldnt tell you when it was last serviced. Bought it 2 years ago and I havent had it serviced.
    VX lumina
    Apr 2007
    Callington SA
    Do yourself a favour, give the transmission (or get it done) a service. Should fix all your problems.
    VT Acclaim
    Apr 2009
    Appreciate your advice.
  1. Replies: 0
    Last Post: 17-11-2008, 01:51 PM
  2. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
  3. auto transmission out of VS HSV
    By lilkel in forum Parts And Other Items For Sale
    Last Post: 09-11-2006, 01:23 PM
  4. Dropping auto sump with extractors
    By lazza44 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2006, 03:09 PM
  5. using auto dropping back to first
    By brentons_house in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2006, 04:44 PM
