| VT - VX Holden Commodore (1997 - 2002) Talk about anything relating to the VT - VX Holden Commodore. |
03-06-2005, 10:29 AM
Ride: VT S'Pack S11
VT gearbox problems
hey guys,
I recently bought a manual VT (V6) and I have having a few problems putting the car into gear
When the car is in nuetral, hot or cold, i cannot put the car into any gear, no matter how hard i push or which gear I select! I can be seriously sitting at a set of lights for a minute or so trying to put the f****r in gear!
When I finally get moving, there is a clunk to pretty much every gear change! Does anyone have an explanation or maybe any idea what is causing the problems.
Any help would be greatly appreciated,
Adam
03-06-2005, 10:42 AM
Tiger
Ride: VTII S 00'
Auto or Manual?
__________________
Chris
74' HQ Premier.
03-06-2005, 02:49 PM
Off to Summernats 22!
Ride: Ride: Ride: Ride: Ride: Ride: Ride: Ride:
Quote:
Originally Posted by VT_Mania
hey guys,
Well, i own a VT V6 manual too, but i dont have that problem (yet!) it sounds to me like the synchros might be shot in your gearbox...have you drained the oil out and changed that? check the old oil for metal fragments and stuff...let me know how you go
03-06-2005, 03:56 PM
Ride: VT S'Pack S11
clutch??
yeah i have been told that the clutch is at fault, however I have a brand new clutch in it
anyway, i am takin it to a gearbox specialist tonight after work so I will let ya know how I go!.
03-06-2005, 05:32 PM
Ride: VT SS 5.7
could be the slave cylinder, had problems getting mine into gear no one knew what it was got the slave cylinder changed and it was fixed.
04-06-2005, 01:57 PM
Quote:
I had a think about it last night and i thought that it could be a problem with the clutch...what's the chances of ALL the syncros going?! after all that, it could be a selector fork problem, maybe even some needle bearing gone on your shafts....surely i nailed it with ONE of those...
09-11-2005, 07:59 PM
Ride: N/A
Did you bleed the slave cylinder underneath the tranny? I just replaced my clutch and when I tried to put it in gear I couldn't. I then bled the clutch and all was sweet.
10-11-2005, 07:40 PM
Ride: VS Acclaim
dunno if i can help but a mate of mine had same problem but he owns a 91 liberty manual, no matter how hard u try its a bitch to get it into gear and it turned out to be his clutch lever, dunno if commies have one but my 2c
10-11-2005, 07:54 PM
Ride: LX Torana - VX SII Lumina
im guessing that the clutch is out of adjustment, probably not completly dissengaging, or one of those things ecotechmaniac suggested
__________________
You can sleep in a car....But you can't race a house!!!
10-11-2005, 09:13 PM
Ride: N/A
I think it sounds like an adjustment problem or leak.
If the system is hydraulic" look under the car for leaks around the slave cylinder, or for a leaking master cylinder, check for leaking fluid on the outside/inside of the firewall, feel the carpet etc. If the previous owner ran it out of fluid, then topped it up without bleeding, it may have air in the system and will do what you describe. Solution fix leak, and bleed the system.
If it is a mechanical or cable operated clutch, look for worn joints/cable ends that are about to break, or bent levers/forks inside the bellhousing (a common problem in older holdens, not sure about VN-VT though.
At one stage or another I have had all of the above problems. Damn holdens! :-)
10-11-2005, 09:26 PM
Ride: N/A
Forgot to mention:
When you can't get into gear at the lights, turn the motor off, select the gear, restart motor then drive off. It will make it easier to drive until you get it fixed.
Be careful, as I had a slow leaking slave cylinder once (I used to top the fluid up once a week), that over night changed to a fast leaking one, and while I was waiting at an intersection the damn thing leaked the fluid out, and the car started to move into the intersection while I had my clutch pedal still held firmly to the floor. Luckily I was quick enough to turn the motor off.
I fix hydraulic leaks immediately now!!
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Gearbox Problems
rus |
VR - VS Holden Commodore (1993 - 1997) |
2 |
26-06-2006 01:41 PM |
Gearbox problems
Smack_SPAK |
4 |
05-04-2006 12:14 PM |
gearbox problems
invasion |
VN - VP Holden Commodore (1988 - 1993) |
1 |
02-02-2006 06:44 PM |
Gearbox problems
hsvd_g |
2 |
25-08-2005 02:17 PM |
Gearbox Problems
STRiFe |
4 |
22-06-2004 04:53 PM |
Mobile Phone | 芸能人 | Massage Classes | Online Image Resizer | Myspace Layouts | Car Reviews
