Results 1 to 2 of 2
Thread: Fault 57??
    vs
    Apr 2009
    Default Fault 57??
    Hi all. Newbie here thought i better say hello before asking a question. Hello. Now on with the question.
    I have a VT with a fault code 57, Injector voltage monitoring. At the same time the righthand O2 sensor is changing between rich and lean.
    Any idea what this is and how to fix?
    vx v6 supercharged
    Mar 2009
    not sure on your fault code 57 but your 02 sensor should flick from rich to lean you can get a scan tool on with the scope function and it should be an even up down pattern if not your 02 sensor is faulty.
    cheers
    shaun
  1. Is this VP fault, V6 fault or just bad luck?
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2006, 10:46 PM
  2. vr bcm fault?
    By markovr in forum Electrical Wiring / Questions
    Last Post: 23-07-2006, 05:50 PM
  3. fault 31
    By mark1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2006, 07:32 PM
  4. VS air con fault
    By telmac in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-01-2006, 09:06 PM
  5. Fault light came on but reports no fault
    By VRBerlina05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 07:21 PM
