Results 1 to 3 of 3
Thread: vt has a miss.
    2000 VT S Tiga Mica
    Jun 2008
    vic,melbourne
    Default vt has a miss.
    hey guys just wanna ask a question see if any mite be able to help...
    my vt has a miss that seems to be WORSE when the car gets hotter, i can go outside in the morning start the car up and i wont feel the miss for maybe 15ish mins and then it just gets worse.
    Few things i have done already....
    plugs,leads, fuel filter, cleaned throttle body(on car just using throttle body cleaner).
    i scanned the car at work and it came up with AFM so i changed that and cleard the code and that works fine now, but didnt help the miss only my fuel economy....what other sugestions do people have? something simple i have missed ?
    only other thing im going to do tomorrow when i get to work is a compression test and see how that goes.
    thanks in advance.
    *edit* its a s2 3.8l v6
    Last edited by StevenzZ; 07-04-2009 at 09:39 PM. Reason: forgot to mention engine :S
    VU Storm
    Jan 2006
    check the plugs while the engines cold, make sure they aren't loose.had the same issue with mine even after changing the plugs, just hadn't tightend em enough
    How to be a good Australian Citizen: Drive a Camry, Become another number in the system, Dob in all other numbers for un-numberlike behavior (no matter how slight), Base all your opinions solely on the information provided by T.T. and A.C.A., Believe everything our gracious Government Tells you to.
    vx v6 supercharged
    Mar 2009
    check injectors may be a dirty injector if you can check injector pulse as well if not wait on compresion test and go from there process of elimination
  1. vp miss
    By half in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2009, 09:23 AM
  2. ok what did i miss?
    By wildss in forum Site Feedback / Site Problems
    Last Post: 24-12-2008, 09:45 PM
  3. Near Miss???
    By JMiller in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-08-2006, 10:36 PM
  4. Bad Miss
    By part2 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-02-2006, 06:48 PM
