Results 1 to 15 of 15
Thread: Unable to open car..?
    VT Acclaim
    Oct 2008
    Default Unable to open car..?
    My 99 VT wouldnt open the other day, brought a new key with hope of getting in and using new key. BUT, after trying evrything and having TWO Racv guys look at it, doors will not open. Tried everything bar smashing windows haha.
    I was under the impression it could be the central locking module or B/VCM unit? But i was told i need to get INTO the car to have them checked,
    So, in short what are my options? Call locksmith? Tow to mechanics and smash window to get in?
    Flash.
    VT spac super6
    Nov 2008
    Riverton sa
    so youve tried with the key manualy?
    if not try the boot and open the seat up if ya can and climb in.. unlock a door from the inside
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    i thought that you could still unlock a VT with the key - even if there were no power going to the car.
    the lock itself is mechanical, it shouldnt matter if the BCM (or whatever) is stuffed.
    when you turn the key, a rod attached to the barrel is moved which unlocks the locking mechanism which is inside the striker - this is how it usually works.
    i cant see a VT being any different.
    i would say your barrel is stuffed or the plastic clip on the rod has broken off.
    whats wrong with the old/original key anyway?
    If you cant get in through the boot (dont know if its even possible - just a suggestion) then you might have to break out the wire coat hanger or packing strap.
    you really dont want to break a window, not only is it a hassel to replace, youll never get all the fine fragments of glass out.
    VP Exec
    Mar 2009
    Melbourne, bayswater
    Acouple weeks ago my central looking wasnt working, it would only unlock the drivers door, that happend because the battery was flat...
    If you can open the boot then climb through the middle of the back seats and your done.
    And you dont need to take to a mechanic to smash the window in.
    nick3110's Avatar
    nick3110 is offline 2.5" Catback
    VX Berlina S2
    Nov 2008
    u should still be able to open the car with the key manually..
    haha too bad if he had gas, he can't get in through the boot lol..
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    Quote Originally Posted by VnPlayer View Post
    haha id like to see him drive it to a mechanic to smash the window
    VT Acclaim
    Oct 2008
    The lock is not being opened by the key, its simply spining in the barrel.
    Davway, ive tried to pop the lock in side, wouldnt budge. Tried to hit the micro switch, wouldnt open either.
    Tried the boot, but cant open the middle seat to climb through.
    The keys just shagged, buttonns stuffed etc so i brought a replacement because i only had one.
    VS l67 statesman
    Dec 2008
    If you have to smash a window , get the windscreen removed and climb through it would be a lot easier than trying to replace any of the other glass
    vt v8 sv exec 044
    Oct 2008
    sounds wierd i know but if i leave my key no1 on the counter it wont open the car
    if i have the key in my pocket when im out etc it will work dont know if it has something to do with it heating up in my pocket but its been doing it since about 2007 and still does it now
    key no 2 has no problems
    vt executive
    May 2008
    ok so the key key spins in drivers door so that lock is stuffed but it did open the boot so the key is working did you try your passenger door with the key as you didnt mention it in any of your post also with the rear centre seat seaction from within the boot use a flat head screw driver to pry it downwards and press against the seat hard and it will pop open
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    hmm thats weird... if you deadlock your doors like i always do (press button twice instead of once when locking) you wont be able to open it manually...
    Going where no late model stato/caprice has gone before.... GAME ON!!
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by minitsbay View Post
    ....... did you try your passenger door with the key as you didnt mention it in any of your post.......
    On later model commodores the driver's door is the only one that can be opened with a key.
    MY RIDE
    vt exective
    Oct 2006
    Get your spare key to unlock the car use the new key to start the car and then the new key should work to unlock your car next time you try ,,,
    VX Executive S2
    May 2006
    Frankston South Vic
    we've covered this before, if battery is flat jack car up and connect charger to starter motor cable and body earth. leave charge for an hour or two then try again with remote. racv should be able to get in unless you deadlocked it
  15. #15
    VT Acclaim
    Oct 2008
    Yes, its dead locked. Ive mentioned that.
    And the battery is not dead. I found out the old owner changed the igniton barrel but not any of the locks. So my key doesnt fit and ive got a locksmith coming tomorrow to change the locks to my current key
  1. can't open VX!!
    By P007 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-01-2010, 06:34 AM
  2. Open ECU.
    By soop in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-12-2008, 07:16 PM
  3. unable to post in parts for sale section...
    By Andy68 in forum Site Feedback / Site Problems
    Last Post: 12-07-2008, 07:05 PM
  4. unable to load pics?
    By cxcxcxvcvcvc in forum Site Feedback / Site Problems
    Last Post: 13-05-2008, 09:01 PM
  5. unable to get 4 channels working
    By vx-s_Man in forum Car Audio
    Last Post: 05-03-2006, 07:59 PM
