Results 1 to 15 of 15
Thread: Can i change a head gasket in a day?
    VT EXECUTIVE
    Dec 2008
    Default Can i change a head gasket in a day?
    Okay here it goes. I have had a intermitent overheating problem in my VT V6. I have draned and flushed radiators and stuffed around with numerous other things but it will still over heat at inconsisent times. A friend of mine says he had the same problem and it was a head gasket. She has been using a bit more water than usual and has developed a bit of a hesitent miss at times.
    Can anyone suggest if I can change the head gasket with minimal mechanical experience. What sort fo time frame am i looing at to do this?
    I have one of those gregorys manuals that explains it, but i dont want to get myself in a mess over the weekend without any transport.
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    The reality is - things can and will go wrong.
    If you've never done such an operation, it's best to give yourself a few days 'error buffer' after you start the operation.
    you'll need more specialized tools like a torque wrench, for example.
    if you follow the gregory's book closely, there's no reason you shouldn't be able to do it - but allow for stuff ups, breakages, etc. (so don't expect to have it ready by monday ) - specially cause you can't buy parts on a sunday afternoon!
    anyway - before you rip the heads off - go visit a mechanic and see if they can diagnose it for sure - it could be something as simple as a heater tap leaking - and the miss could be unrelated.
    does your oil look like custard?
    do you get steam out the exhaust when car is warm?
    vt s s1
    Mar 2009
    When you say minimal mechanical experience how much exactly?..
    Agree with luke, dont start ripping the head off until you know for sure its ahead gasket. Have you checked your oil? If its head gasket the oil will be a milky colour, also try this.. when the engine is cold take the radiator cap off and start the car and post your results.. Or just take it to a mechanic and see if they can check it out for you.
    -Michael-'s Avatar
    -Michael- is offline Ooh Yeah.
    VT S Pack
    Oct 2008
    vt executive
    May 2008
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Quote Originally Posted by minitsbay View Post
    i have same problem mine isnt heads its intake maniold gasket
    i was about to add this, its usally this first... commonly confused
    aZk.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Took me a day for intake manifold. Remember oil changes and coolant changes take a bit as well.
    You cannot do it properly in just a day. What if you need to deck the heads etc ? Gotta clean up the block properly etc.
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    when i did my head gaskets on my old VC i thought it would take too long, then i found that the cylinders need cleaning, then i learnt how much scraping is needed to get all the old gaskets off (ALL OF IT), found out my lifters were shagged and needed new ones, found a bent push rod and had to clean the others ect ect ect ect.
    Dont rush it, get the gregories book and take ur time, have all ur tools ready and have a big clean table to sit all the rockers and pushrods in so they stay in the correct order. You will know so much more about ur motor afterwards lol!
    Best of luck mate
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    vt
    May 2009
    i am having same problem too,
    my car just broke down and my radiator was empty
    so i refilled it again rying to drive the car home untill the engine is having knock sound now
    then today i start pull things apart
    open the inlet manifold and found the coolant inside mixed with oil
    so pls guys i need help too
    is my car problem worse about the knocking sound? need help pls
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    mitmit ; You shouldnt pull anything out b4 testing few items ;
    Water pump efficiency, thermostat operation ,radiator leakage ,cooling sys. pressure test and finally compression test.
    The water u've just seen (after taking the inlet man out) came from the manifold ,cause u've tilt it whiletaking it out ,oh if its green wouldnt worry about it too much,but if its caramel brown ,yeah go and replace whatever.you fancy.
    Knocking noise is very common for these engines.There is no quick fix.put up or spend $$$.
    VT SII V6
    Oct 2006
    peanut i had the same issue car would heat up rapidaly from normal temp to hot and hot light flashing in about 3-4 seconds it would sit on hot for 30 sec or so then it would cool down to normal in about 3-4 seconds it was my thermostat i replaced it and it was fine after that give your cooling system a good flush as well if it hasent been done for a while thermo about 20 dollars worth a try b4 go ripping engine apart
    VT Acclaim
    Jun 2009
    hey there,
    I got oil in my water... brown oily gunk.
    can only come from one place.... right?
    these are famous for requiring head gasgets.... I went to turners auctions a while ago looking for ex police vt sedan and found two... they both had combustion gasses in the radiator at an estimated cost of about nzd2000 to repair, they both sold for over nzd8000 which I didnt purchase.
    did they fix it with the VY?
    Vx S pack m5
    Sep 2007
    keilor down, vic
    do you know if its a stuffed head gasket or and inlet manifold gasket? I'v been told its rare for headgaskets to go on ecotecs and will more likely be a inlet manifold gasket. No real easy was to tell them apart untill you take things apart.
    Jul 2006
    THese engines have some of the least head gasket occurrences out there, the GM Graphite gaskets are that good that mechanics rarely believe it, and reputable engine performance engine builders preferring them over the rest, such as Sams Performance.
    A pity they couldnt follow up with the intake manifold gasket as they are probably the worst ever put on a car, in Series 1 and 2 v6 engines. It cost them heaps in the U.S over the years, but probably made heaps back with their replacement gaskets. DO the intake gasket first, you will see if it is that or not when you remove it, if its fine, then your only 16 bolts away from taking off the head (must remove rocker gear).
  15. #15
    Lewie's Avatar
    Lewie is offline B Cast and flat topped!
    Very thirsty VT & VH project under way! YAY!!
    Nov 2006
    Nowra, NSW
    I had a similar problem in my 98 VT. I found it to be a sticky thermostat.
  1. Cracked head? blown head gasket???
    By VL_5SPEED in forum General
    Last Post: 09-01-2010, 10:41 AM
  2. inlet manifold gasket, change
    By hN! in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-11-2008, 04:20 PM
  3. Blown head gasket or cracked head
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2006, 07:52 PM
  4. Ditz can't change a flange gasket
    By funkynoodle in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-11-2005, 07:53 PM
  5. Head gasket
    By sleekism_69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2004, 02:10 PM
