Results 1 to 9 of 9
Thread: Brake fluid flush
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Default Brake fluid flush
    I want to flush out the old brake fluid as it hasn't been done for about 40,000 kays .I noticed that the fluid reservoir has some crap in it and was wondering if i took the reservoir off to clean it then filled it up with new fluid then bled the brakes would this have any effect on the ABS ? I was told that you have all sorts of problems if you get air in the ABS hydraulic control module .
    Thanks in advance.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Yes, unless you know how to bleed the master cylinder as well, dont take it off. SOmeone on here may know the technique. It will be in a car manual. Different to bleeding the brakes only. They may have a tool for it.
    VX lumina
    Apr 2007
    Callington SA
    The way to bleed the m/cyl is to undo the brake lines and just to let drain until no air comes out ,so I would assume that you can remove the reservoir to clean it with no major problems.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Somehow I double posted when I edited, read next reply.
    MY RIDE
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I believe if air gets into the system before the ABS module it requires a special procedure to bleed the ABS module, this will happen if you remove the reservoir. I have seen the proper procedure somewhere on this forum.
    MY RIDE
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Suggest that you remove the old brake fluid from the master cylinder using a syringe or equivalent (I use a turkey baster), when empty clean out the master cylinder using a rag or kitchen paper, refill the master cylinder with new fluid and then bleed the brakes. When cleaning, some fluid still stays at the bottom of the master cylinder where the tubes connect so you won't let air into the system.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Quote Originally Posted by BlackVXGTS View Post
    Turkey Baster, I'll have to remember that.
    A few weeks ago I decided to change my brake fluid, so I thought a syringe would do the trick, where can you get a syringe from....chemist! I'd just finished working on my brakes, so picture this. 21 year old male, wearing unironed t-shirt, shorts and thongs, dirty as from the brakes, in a hobo suburb asking for a syringe . Girl behind the counter said they didn't stock them even though a senior staff said they keep them behind the counter. I decided not to make an issue out of it.
    Ronald Reagan (1986)
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Thats what i ended up doing , but i used a piece of clear plastic hose to suck the fluid out then cleaned out the reservoir with paper towel . Topped it up with fresh fluid then bled the old remaining fluid out of the system . Its amazing the difference it has made.
    VX Executive S2
    May 2006
    Frankston South Vic
    just bleed some fluid out until nearly empty then clean inside reservoir with lint free rag, top up and bleed until nearly empty, then fill and bleed as normal
  1. Brake Fluid
    By Haydz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2009, 08:56 PM
  2. how much brake fluid??
    By VL Berlina 5speed in forum General
    Last Post: 24-11-2008, 01:55 PM
  3. brake fluid flush
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2008, 05:32 PM
  4. Brake Fluid Flush
    By Darren in forum General
    Last Post: 01-09-2007, 11:41 AM
  5. Brake Fluid and Auto Trans Fluid.
    By Melchior3 in forum General
    Last Post: 20-02-2006, 11:49 AM
