how do you remove vt rear cluster light - have looked
thanks guys
Are you talking about removing the rear assemblies or the globes?
If the assemblies. Lift the boot. There are two screws holding each assembly in place.
Once these are undone pull the assembly away from the car in either a left or right direction, depending on which side you are taking out. This is because there are two pins which hold each assembly in.
Originally Posted by Reaper:
Originally Posted by Jecs:
u need 2 remove the shifter surround, stereo, lil compartment above 12V supply, dash surround. Then drop the steering wheel down 2 give u more room then remove the cluster. then the globes u get access from the back of the cluster, its as easy as that.
