Results 1 to 5 of 5
Thread: VT Air Intake
    vt s s1
    Mar 2009
    Default VT Air Intake
    Hey guys someone told me bout taking the pipe from the entry to airbox to the radiator completely off and said it made more power to the point his clutch was slipping. I didnt think to ask at the time cos he said i should try on mine and jw, even if it did bring a little more power i dont see how exactly iyt could damage the clutch? He said he took it back to holden and they replaced the clutch..
    Would there be any problem taking off the front intake pipe?
    Thanks
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    I'd imagine there'd be less restriction on the flow however when the engine/radiator heats up you'd be sucking in heat which cant be good.
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    Dont do it. Your 'mate' is a clown.
    no longer a hoon by association - the commodore is gone
    kart_racer is offline Races karts
    VT Acclaim 5M
    May 2008
    It was a placebo effect. Your mate thought he had more power so he was revving it harder on take offs and finished off his clutch.
    It'd be worse for power, dragging in hot air from the engine bay....which is the whole reason they made the intake to take air from above the radiator...
    vt s s1
    Mar 2009
    Thanks guys ive put it back on but just gota get new clips for it cause the ones they came with are shithouse so atm its sorta just sitting there lol.
  1. normal air intake vs pod filter vs cold air intake: fuel economy
    By existentialist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2011, 09:38 PM
  2. Vx Air intake
    By Wokka in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-12-2008, 04:14 PM
  3. lol @ intake!
    By kwik6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2006, 08:26 PM
  4. VS air intake
    By Jamie_87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-12-2005, 12:03 PM
  5. Vn Intake
    By sean lawrence in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2004, 09:08 AM
