Refilling radiators
When refilling an empty cooling sytem, the panel shop I worked for used the following method.
Open the heater tap (turn the heater control to the red area).
refill the system with the coolant mix.
Run the motor with the radiator cap off,
As the engine warms up, the thermostat will open, letting air trapped in the engine block come out through the open radiator cap hole, it may take 5 or 10 mins for the engine to "burp" out all the air as each time the cold coolant hits the thermostat it will close, until all the coolant is the same temp and the thermostat stays open.
Then replace the radiator cap, allow the cooling system to build up pressure and visibly check for leaks, especially at hoses/housings that you may have had undone.
Be wary of moving belts and fans, as thermo fans may start up unexpectedly.
If there are bleeder valves, of course open these before the coolant gets too hot or you may get burnt,
The blowing (while the coolant is cold) method, mentioned in the post above, sounds like a good idea also.
On some cars that had the heater in odd spots, it was sometimes nescessary to slip a heater return hose off momentarily to allow trapped air to escape (before the coolant gets too hot)
You can trouble-shoot air in heaters or faulty heater taps by feeling the hoses, if all is well they will feel the same temp as the radiator hoses, if blocked or full of air they will feel cooler. Sometimes squeezing the hoses is enough to burp the air on further in the system to where it can find its way out.
If you have to add water to an already hot engine, do it while the engine is running and add it slowly as there is a risk of cracking blocks and heads and also of boiling water erupting out the filler hole and scalding you, better to wait for it to cool naturally, much safer.
I always check my vt coolant via the radiator cap (when cold) as I do not trust sealed sytems, how they work is, as the water expands with heat, it is pushed out into the radiator overflow bottle, when the engine cools, it is sucked back into the engine. If you get a small leak in the system
(EG:pin hole in radiator or hose), then when it cools, air is sucked back in via the leak. So when you check it via the dipstick in the overflow reservior, all seems ok, but the engine can be half empty.
Just my 2 cents worth, not claiming to be an expert.
