Results 1 to 8 of 8
Thread: irs questions?
    vt clubsport 5L 195i
    Apr 2009
    brisbane
    Default irs questions?
    can anybody tell me pro's an con's of irs suspention?and Fe2?
    tr3nt's Avatar
    tr3nt is offline trent was 'ere
    VP Calais International 5L
    Sep 2003
    Melbourne, AU
    Independent suspension - Wikipedia, the free encyclopedia will help you out relating to IRS
    FE2 is Holden's Optional sports suspension, or lowered suspension however on upper models (ie SS, Clubsport, Calais etc) FE2 was standard I believe. It's Kings equivilent to "Low". If you're spending coin to lower your car and contemplating FE2, can I recommend the next size down?
    Quote Originally Posted by hakhawk View Post
    if you pay for fuel, ill drive up and drive you around in the bmw. assuming your(hopefully hot) date rides shotgun, and you get the boot, dont worry, its well ventilated if ur dates not so, you can share the boot
    VY SII HBD Calais L67
    Dec 2006
    IRS is about maintaining as much useable tyre surface contact with the road under all conditions during suspension travel. Some do it better then others.
    VYII Calais L67
    Apr 2009
    brisbane
    thanks 4 reply.i have fe2 on my clubby but still wana go lower.if i were 2 get ultra low will i need shorten shocks camber kit??will it bottom out when i launch in 1st as i have irs an it sqwots quite abit in the rear??cheerz
    Dec 2006
    Grab a 2 point camber kit along with some better sways and that should complement your new suspension well. Firmer rate springs are the go in commies due to the weight of them
    VYII Calais L67
    Baldric is offline The BOSS
    VE GTS M6
    Dec 2003
    PROS: Handles better in corners,much more road grip faster you go the harder it bites into the road
    CONS: LOL..... depending how HARD you drive your car will depend how many tyres you go through. is notorious for eating inside edges out from squatting
    ___________________________________
    Car: 07 VE SSV 6LTR L98 A6
    Metalic Silver
    Apr 2009
    brisbane
    thanks 4 reply.yea when i launch in first it bites hard in the rear an it makes quite a loud squeek sound when it sqwots would that mean my shocks need replacing or is that normal?also would it be sqwotting so mush due 2 soft worn springs or is this normal 2??
    cheerz
    VE GTS M6
    Dec 2003
    nahh means th tyres are rubbing on the guard go a bit more easy on the gas
    Metalic Silver
  1. 2 questions
    By Torquative in forum Car Audio
    Last Post: 23-01-2008, 11:58 PM
  2. few questions????????
    By zegerman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-12-2005, 05:40 PM
  3. VK Questions
    By The VHK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-12-2005, 12:07 PM
  4. vx questions
    By VL-187 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2005, 08:49 PM
  5. VB questions
    By White202 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-08-2005, 03:34 PM
Tags for this Thread
