Results 1 to 4 of 4
Thread: VX 2 to VX 1 Cruise Stalk Conversion
    Nov 2007
    Default VX 2 to VX 1 Cruise Stalk Conversion
    Hi All,
    Just bought a series 2 VX indicator/cruise stalk to put in my series 1 VX. Now I realise there is a wiring difference, and after many searches can only find a VR to VX2 conversion diagram. Sorry if I missed something but has anyone done it recently and if so much drama? Know how to get it all apart more interested in the nuts and bolts wiring changes. Thanks In Advance.
    Trelos
    mwb235 Guest
    Take a look at this thread and check my "instruction sheet" it will help you do it...
    EDIT: As i did this mod to my VR Calais in late 2001, then my VT Calais (series 1) in 2006, i can confirm that the wiring between VR and VT series 1 (and probably up to VX series 1) is the same or very close to it, so my diagram will work for all these models.
    vy indicator/wiper arms
    Nov 2007
    Thanks for the reply it was your diagram I was refering to. Just another quick one before I pull it all to bits, the cable with the conector on the end that comes off the satlk is a different connection. Just a case of wiring in the old lead? Thanks
    mwb235 Guest
    Quote Originally Posted by trelos05 View Post
    I know the one you mention - from memory the two pins are in the same position, it's just the slots and lugs are in different positions. I don't have a picture of them, but i've drawn a diagram showing the difference - hopefully it makes sense.
    If your plugs/sockets don't match you have two options - modify one of the plugs OR sockets, or cut off the plugs on the new stalks and wire in the plugs off your old stalks. The only downside of the latter method is you can't sell the old stalks (i.e. now missing plugs), so modifying is probably best. Unless of course you can cut off some plugs off a VXII/VY/VZ wreck (Pick 'N' Payless in Blacktown NSW for example let you do this).
    If you modify your exisiting socket, you just need to carefully cut a new slot in the opposite corner to the existing slot (with a razor blade/stanley knife etc). Or, if you modify the plug on the new stalks, just cut off the top lug. Modifying the socket is probably best though, because modifying the plug like i described means it could be connected the wrong way around.
    Attached Thumbnails Attached Thumbnails VX 2 to VX 1 Cruise Stalk Conversion-vr-vs-vt-vx-stalk-connectors.jpg
  1. inducator/cruise stalk
    By darren44 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2009, 07:35 PM
  2. VT/VX Cruise Stalk
    By Indy_387 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-03-2007, 06:32 AM
  3. cruise / indicator stalk
    By Dayvo in forum Electrical Wiring / Questions
    Last Post: 14-07-2006, 03:02 PM
  4. indicator stalk
    By filtnineee in forum Electrical Wiring / Questions
    Last Post: 29-01-2006, 03:53 PM
  5. Indicator stalk w/ cruise control
    By Liddz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2005, 01:22 PM
