Results 1 to 11 of 11
Thread: L67 Pulley upgrade
    VX Calais S/C
    Nov 2008
    Question L67 Pulley upgrade
    hey Guys...
    I have been looking at the pulley upgrades out there for the super six's and noticed that there are two options out there that are cheaper than FIT's $534 package.. the first is the option to buy the pulley and use a press to fit it, i thinks its about $190 or so, just wanted to see if anyone has tried it and how it went?
    Then there is one at holmart.com.au where it costs $398 but you need to buy the pulley romoval tool, is there another way I can remove the pulley with out having to fork out $200 for the pulley removal tool?
    Cheers Guys!
    VY SII HBD Calais L67
    Dec 2006
    Yella Terra press on pulley is the go. You can remove the snout from the charger and use a bearing press if the tool is out of reach for you.
    There are plenty of blokes around with the tools on the forums, maybe post a wanted to borrow ad?
    VYII Calais L67
    VX S Pack L67
    May 2005
    I've spoken to Holmart about that pulley package, he said even he reckons it's a rip off and can't remember ever selling one. The Yella Terra ones are the cheapest or maybe check out zzperformance American website, same stuff for the same engine but much cheaper.
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    Supercharged VX S
    Nov 2006
    Mate I did the Yella Terra10psi pulley up grade awhile ago, I didn't have the tool to take the pulley off but my mechanic contacted Yella Terra direct and bought one through them. So ask around the mechanics in your area to see if any one has the tool.
    Its a great upgrade to, you will be very happy when its done.
    VX Calais S/C
    Nov 2008
    redcv6's Avatar
    redcv6 is offline supercharged intercooled
    vy ss ute, diesel landcruiser 100s, hq panel van
    Aug 2006
    Ringwood
    vt s/c spak
    Apr 2007
    yella terra where doing a change over a while back, when i did mine, cost me 220.
    gave them the old one, the gave me the new one..
    the difference with the 500 buck jobs is the snout is tottaly remanufactured, and has bigger bearings etc..... to cope with the greater loads that are \\placed on it due to the constant higher reving,,,,....
    davo.....
    VS l67 statesman
    Dec 2008
    Mar 2008
    Well it depends on what you want out of your car now and later on down the track.
    For instance if you never plan on running an intercooler or getting a custom tune then your best option might be to get the YT press on pulley
    However if you decide you want more boost down the track, then bang for buck you can't go past a modular pulley setup.
    If not, it may work out being more expensive if you had to replace the press on pulley because you want more boost down the track.
    We supply these boost upgrade kits for $295, including the loan of the pulley removal and installation tool.
    The factory snouts are plenty strong, strong enough to last powering cars in making over 400hp at the treads in the US, and other high end competition cars here locally
    s/charged vt and vy on 20's
    Mar 2009
    I used the mace pulley. soak area with wd40 or similar, grip behind pulley, wind a bolt into the thread and press onto the end of bolt. Use 3 long bolts to wind new pulley on. wind 2 bolts into the new pulley and use these to lock a screw drive into. then simply wind the pulley on with the other bolt and a heap of washers. Order new gasket before fitting, rubbing the surface with wet and dry will help too, dont press too hard.
  1. vt pulley
    By lgr_lgr in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2008, 05:11 PM
  2. where to get my pulley installed?
    By lockmac in forum V6 Development And Modification
    Last Post: 13-06-2008, 10:28 PM
  3. pulley upgrade or straght chip
    By flip1906 in forum V6 Development And Modification
    Last Post: 07-11-2005, 09:15 PM
