Results 1 to 8 of 8
Thread: VZ 6.0ltr into WH
    vs 5.0l
    Feb 2007
    Default VZ 6.0ltr into WH
    I have just purchased a manual, stacked vz clubby to transplant motor and running gear into my auto 2002 wh stato.
    Some questions i need answered before i begin my conversion.
    1. Wiring looms: Are they the same? what plugs strait up and what doesn't?
    What needs to be changed/modified? Can i keep my standard stato dash, c/c, cluster and everything?
    2. What is involved in putting the 6 speed in my stato? Does anythin have to be changed? I understand pedals and other bits and peices but what bout speedo, computer, body control module, anythin?
    Has any1 done this conversion and how hard is it?
    vs 5.0l
    Feb 2007
    is any1 goin to point me in the rite direction. can't get any sence out of the search
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    either keep searching or try the internet.
    i doubt there would be many, if any of these conversions out there.
    Id only be guessing on most of it so ill leave it for someone else that may know.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    try googling LS3 into vx (basically the same as a WH) you might have more luck
    MY RIDE
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    I would assume the loom is going to be different, because Ls1 and ls2 and going from auto to manual. And you will have to get the tail shaft modified as well. Because the statesmans are a long wheel base like the ute and wagon, obviously different to a sedan
    vs 5.0l
    Feb 2007
    Any more info much appriciated guys. i have seen a ls2 stroked to a 7ltr put in a vx clubby with the standard dash and intruments. there has to be sum1 out there with this info
    VT Calais
    Apr 2007
    there are cam timing sensors that need to be changed to the vt sensors. involves pulling apart the motor to get to them.
    VX SS
    Jul 2005
    East of Melbourne
    Do a search for a thing called a 'Reluctor Wheel' it is a toothed wheel which sits near the flywheel, there is a sensor that reads off that wheel to tell the computor the precise position of the crank as it rotates, the LS1 runs a 24x reluctor wheel and 1x cam gear, whilst the later engines run a 58x reluctor and 4x cam gear. To change the reluctor wheel the crankshaft has to be removed from the engine, however I have read that there is now some sort of 'Trigger conversion box' available that will convert the 24 signal to a 58 signal so gets over the problem, not sure how good they are, probably need to talk to one of the specialised LS1 workshops. I could probably find a link to the conversion box with a bit of a search, been reading up a bit on it myself as a future conversion for my VX SS.
    Found a bit on the conversion box...Used when fitting a 58x reluctor engine into your VT-VZ so you dont have to change the reluctor and cam wheel
    not sure how well they work.
  1. VZ SS 6.0ltr mods?
    By dan-0 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-11-2008, 08:21 PM
  2. Vn Bt1 Rebuilt 5.0ltr
    By oyamum in forum Vehicles For Sale
    Last Post: 13-02-2008, 10:42 PM
  3. 5.0ltr differences?
    By Panama in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2008, 06:16 PM
  4. vr 5.0ltr 5spd
    By Kruza in forum General
    Last Post: 14-01-2008, 08:31 PM
  5. VT 5.0Ltr LSD problems HELP
    By Pyrod in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-07-2006, 08:09 PM
