Results 1 to 7 of 7
Thread: mechanical questions/enquiries...
    callum_88's Avatar
    callum_88 is offline Donating Member
    VT Exec 5 spd/ VZ SS 6 spd 6ltr
    Nov 2008
    Salisbury Downs, SA
    Default mechanical questions/enquiries...
    just a couple of questions because im not that mechanically literate
    i have a vt v6 5speed
    - i smelt a strange smell after reving her about 3,5k-4k then changing gears, it comes through the heater when thats on.
    - also when i get out the car i smell a wierd smell which is different to the first, im guessing it may be the clutch ...
    (im not sure if its normal but whenever i engage the clutch i get a big jolt in the whole car, and i think people reckon im not a very good driver :P ) i try to release the clutch fairly slowly but it still does it, do i need the clutch changed?
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    it sounds like you have a slipping clutch, i would swap the clutch for a new one or have a mechanic do it but yeah it sounds like you either have No clutch fluid or you clutch plates are slipping
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    callum_88's Avatar
    Nov 2008
    Salisbury Downs, SA
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I haven't got a manual but I would say probably next to the brake fluid reservoir or booster, in the engine bay.
    MY RIDE
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    The clutch fluid reservoir is located next to the brake reservoir. The bleed nipple is located on the drivers side upper of the transmission.
    When you go looking for the clutch fluid it's going to be black, so dont panic and instantly think something has gone majorly wrong
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    What does the first smell smell like ? If it comes through the heater and smells like cooland you could have a leaking heater core. If u do just wait until you get coolant dripping into the front carpet, then replace the heater.
    callum_88's Avatar
    Nov 2008
    Salisbury Downs, SA
    ill have a look at the fluid, cheers
    hmm, well i know my coolant is a bit gluggy and slimy and needs a change, could that be something to do with it?
  1. vn mechanical manual
    By grothie1978 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-02-2008, 05:24 PM
  2. V8's enquiries
    By [JUDGE] in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 01:36 AM
  3. Mechanical Recommendation
    By SWE11L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2006, 10:43 PM
  4. need mechanical help
    By andyman in forum General
    Last Post: 29-06-2006, 09:32 PM
  5. just some enquiries about amps/subs
    By tr3nt in forum Car Audio
    Last Post: 11-04-2005, 09:21 PM
