Results 1 to 3 of 3
Thread: Weird overheating problem
    VS SS
    Jan 2009
    WA
    Default Weird overheating problem
    Ok here it goes
    from cold it starts fine ill take it for a 5-20 min drive and turn it off.. leave it for about 20 mins and i try to start it and it struggles to turn over.. and going through drive thrus etc, it starts going up too the H mark in a matter of minutes.. i can hear the thermos running..ive checked coolant and its fine
    any ideas to what this could be?
    thanks
    vt berlina series 1
    Sep 2008
    could be a stuck thermostat, when its cold take it out and change it , if the old one has scratches on the side of the center shaft its usually a good indication its been sticking , your radiator could be blocked as well , that will cost you more to get done ,so change the thermostat first and if problem persists then take the radiator out yourself and take it to a radiator shop to get cleaned , they will check the overal condition of it also if they know what they are doing , hopefully thats what will fix it , good luck ps: taking it out yourself will save you a pack of money in labour costs ,
    VS SS
    Jan 2009
    WA
    Quote Originally Posted by banga View Post
    How much is a thermostat ment to be opened once it reaches the right temperature?
  1. VY Overheating Problem
    By 1LOWVX in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-03-2009, 08:52 AM
  2. overheating problem
    By Eliminator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2009, 02:45 PM
  3. Overheating problem.
    By GIMPEESS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2007, 08:14 PM
  4. VC Overheating Problem!!!
    By tarbs in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-04-2006, 10:42 PM
  5. weird overheating problem
    By vk6hgr in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-01-2006, 10:50 PM
