Results 1 to 22 of 22
Thread: VT ex-cop Traction control issue!
    1995 VS Executive
    Mar 2009
    Default VT ex-cop Traction control issue!
    hey guys
    my mate has an ex cop VT it has traction control and when it also has lsd this is simply unacceptabe and it needs to be switched off ....
    BUT....
    It has no tracton control button, no fuses or relays that are marked to have anything to do with traction control and its not linked up with the abs either as we have pulled out and played with all the fuses and relays and nothing will turn it off
    Does any one have any idea how we can fix this problem
    any help would be great
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    dont try pull out relays or fuses im pretty sure its linked with the abs...
    Going where no late model stato/caprice has gone before.... GAME ON!!
    1995 VS Executive
    Mar 2009
    well we took out the ABS fuse and that stopped the abs from working but traction still stayed on .....
    walesy's Avatar
    Jun 2005
    Perth SOR
    oh ok i thought they were linked... an auto electrician might be able to put a switch in? ... it does come in handy having a button for it.. as u can see in my avatar
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    there is no traction control on Police Vehicles.
    heres what they do have though:
    http://www.aic.gov.au/publications/p...gs/18/hill.pdf
    section 218 - Is there already a National Police Car
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    yeah every police vehicle i have seen in VT/VX does not have traction control as they were executives with the Police Pack in them
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    1995 VS Executive
    Mar 2009
    well its a police pack its manual says so and so do the engine plates, it has the the fuses and wiring for all the lights and it has traction control haha it'll spin for about 1.5meters and then will grab and no more loss of traction on dirt,wet road and or grass....
    either foot to the boards or keeping it in 1 on the auto ???
    anyway i dont think wer gonna figure it out
    thanks for the help anyway guys
    fitz_vt's Avatar
    Nov 2008
    Quote Originally Posted by t-rav View Post
    ABS and TCS Control Module are the same according to the Holden Workshop manual and my gregory's one as well.
    ABS works off of a Fusible Link in the engine bay and fuse 27, TCS works off of the ABS module.
    The way TCS works is by applying brake pressure to the certain brakes that have lost traction, though the ABS modulator, upon the wheels braking, the vehicle regains traction. there are also various torque sensors throughout the vehicle and attached to the engine these sensors provide data to the central unit at the ABS module so that when ABS is turned off Traction Control is turned off too. so if you take out the ABS/TCS Fuse Fuse number 27, it should not operate.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Sell the car and buy one with a switch for traction control.
    redcv6's Avatar
    redcv6 is offline supercharged intercooled
    vy ss ute, diesel landcruiser 100s, hq panel van
    Aug 2006
    Ringwood
    go to someone that tunes cars they should be able to turn it off permanently
    VT exec
    Sep 2008
    hey i have an ex cop vt commodore aswell and let me tell you they have tractin control like hell. and it cant be turned off unless you go to ultra tune and get them to permantly disable traction, then good luck with taking corners fast :P
    Sabbath''s Avatar
    Jul 2006
    Quote Originally Posted by fatboy15 View Post
    Sounds like you need better tyres/suspension.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    The only recommended way of disabling the ETC system is to disconnect terminal 27 from the ABS/ETC Control Module connector YE98, circuit 1427, Black/White wire (actual torque). This is to be achieved by withdrawing terminal 27 from connector YE98 and taping the wire back to the main wiring harness. This will disable the ETC system while maintaining normal ABS operation.
    If the ETC system is disabled, the TRAC OFF warning lamp in the instrument cluster will be permanently illuminated when the ignition is on and Diagnostic Trouble Code 74 will be logged. At no time must the ‘TRAC OFF’ warning lamp be disconnected as its function is to advise the driver that this safety feature is not available.
    VX Exec 01
    Aug 2008
    Melbourne, Vic
    are you sure it has traction control and your just not used to a heavy car with an lsd and probably alot of rubber?
  15. #15
    VX acclaim wagon S1
    Feb 2008
    sydney
    cut pin B11 at ecu, black/white trace.
    that will disable traction control (if it has it) the wire will be there if it has it or not, this will also illuminate the light on dash permanently,
  16. #16
    1995 VS Executive
    Mar 2009
    Quote Originally Posted by BlackVXGTS View Post
    thanks mate great help
  17. #17
    VR/II 5L UTE
    Sep 2008
    st clair NSW
    just reading through this question, my vt senator manual is the same thing, you can rev it dump it and just get a little chirp from the tyres.
    this wire that can be cut/disconnected, i guess you could put in a switch of your own so as to be able to activate in times of need like wet weather or on the track?
    did this fix the non wheel spinning issues for anyone?
  18. #18
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
    if it doesnt have a TC switch it hasnt got it
    more like torque management I would say
    cheers GM
  19. #19
    Dec 2006
    Nowra
    Quote Originally Posted by redcv6 View Post
    its not in the tune
    cheers GM
  20. #20
    vt 5.0
    Mar 2012
    ngaruawahia
    daggett is offline Crazy Tiger
    Commodore S VT Series II M5 & VT II Wags
    Mar 2004
    Goulburn
    either foot to the boards or keeping it in 1 on the auto ???... I hope your not doing this on public roads.......
  22. #22
    VT SS S2 A4
    Aug 2005
    Quote Originally Posted by daggett View Post
    No he saves this sort of activity for foot paths and playgrounds.
LinkBacks (?)
  1. 22-04-2009, 12:45 PM
  1. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  2. vy sv6 traction control
    By phat_com in forum General
    Last Post: 11-01-2007, 03:56 PM
  3. Traction Control
    By bertvj in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-06-2006, 02:01 PM
  4. Traction Control Issue
    By giannetto in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-04-2006, 04:12 PM
  5. Lpg And Traction Control
    By skb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-04-2004, 11:10 PM
