hey all i went out and got my self a type r shift light and i aint sure how to wire it up as its only got 3 wires on it (red,black,green) i am not sure and i could be 100% wrong but i thought red gose to power and black to earth but not sure on green but i could be wrong with them all so would any one be able to help me i have a vt 5 speed
1st you should have done a search.
2nd Type R are so shit and chances are it wont be able to pick up the tachopulse signal from the wire in the engine bay, to rectify this you will need to a tachopulse signal strengthener which autometer sell for $150 from memory, which kind of defeats the purpose considering your gauge is worth $30.
But if you to go ahead with it:
In the engine bay follow the main engine bay wiring loom from the passenger side firewall grommit, 30-50cm along you will find a Dark green wire coming out of the loom then sticky-taped to it. This is your tachopulse signal wire, connect your green wire to it.
EDIT: do you have a VT?
-Smit
the main plug behind the dash you can wire it in to there. its a brown wire on one side of the plug i had my msd shift light wire in to it and it work great
