Results 1 to 13 of 13
Thread: Front strut tower cracked?
    DanVN's Avatar
    DanVN is offline Cruizin' in style!
    01 WH Statesman International 5.7L
    Nov 2007
    Western Suburbs, Vic
    Default Front strut tower cracked?
    Hey Guys,
    Just pulled a long haul from melb to the gold coast.. 17hrs driving sucks btw.
    Popped the hood today and was just generally checking over the car when i found the top of the strut tower where it joins the body, the glue (or whatever holds it there) has all cracked and there is about a 2mm gap between the strut tower and the body it joins to.
    it is fine along the sides it seems to be just at the top.
    How bad is this?
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    DanVN's Avatar
    Nov 2007
    Yep Found its a common problem, ill get it welded up and stick a Strut brace on there
    VP Executive R-spec
    Jan 2005
    :S gees what happended to all the outback testing and doing jumps over cattle grids. You would have thought they could have banged a prototype up enough to get that to show up pre production
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    Pretty common in the much lower ones from what I've seen, especially if you manage to bottom the struts out.
    Check out my VP right 'ere!
    DanVN's Avatar
    Nov 2007
    Quote Originally Posted by camstatic View Post
    Do it almost Daily, whoever lowered my car was an idiot -_-
    camstatic's Avatar
    VP S1 V6 Executive
    May 2006
    Regional SA
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    if its that low you bottom out then you probably want to make it a little taller as its probably illegal Can you drive over a full coke can without knocking it over?
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    DanVN's Avatar
    Nov 2007
    Nope but a full coke can isnt legal height either its approx 31% too tall :P its 11cm all the way under so legal,.
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    DanVN's Avatar
    Nov 2007
    Not as bad as it sounds, the back can be jacked up with the statesmans auto level to stock height when i need to
    EDIT: im an idiot 11cm :P
    fitz_vt's Avatar
    Nov 2008
    well the police officer that tested my car for height told me to roll over the a full coke can. lol. he must of been wrong.
    but it could be jacked up with the statesman Auto level to stock height when you need it too lol.
    VT Commodore
    Jul 2010
    I bought a VT back in Jan drove it for 3 weeks and found massive cracks in both struts.
    It is a common problem in the VT and VX's it was corrected after that. It went back to the car yard and they repaired it after alot of arguing....its just under 6 grand to fix cracked strut towers cause they have to level the car again and then bog it with whatever they use...EXPENSIVE DAMAGE HUH!
    Its not structual its a cosmetic fault in the car. They are not welded as apparently it stops the airbags from going of. You can't claim it on insurance either as it classed as "wear and tear". Basically in a lowered vt a pot hole can do it..and if its a v8 the power can do it as well!
    So if you repair (6 GRAND!) deffinately a strut brace to minimise the chance of doing it again but it can still happen....in other words they are a problem car!
  1. VIC: $50 Front superlow king springs + monroe GT gas shocks in strut tower
    By PaRaDoX in forum Parts And Other Items For Sale
    Last Post: 17-09-2008, 04:12 PM
  2. VT Series 1 Strut Tower.
    By Old Timer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-03-2008, 10:00 PM
  3. Strut Tower Brace
    By caldonia in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-03-2007, 03:53 PM
  4. Strut tower damage - how to fix?
    By synoptica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-11-2005, 10:51 AM
  5. Strut tower brace
    By blue alliance in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-07-2004, 09:08 AM
