Results 1 to 6 of 6
Thread: strange power steering noise
    callum_88's Avatar
    callum_88 is offline Donating Member
    VT Exec 5 spd/ VZ SS 6 spd 6ltr
    Nov 2008
    Salisbury Downs, SA
    Default strange power steering noise
    when i turn left only say half a turn, there is a kinda of grinding noise and sounds a little bit like liquid or something, i dont get it at all when turning right. im guessing it would either be the power steering rack or pump, but i wouldnt be sure.
    it may have to do with my steering wheel is a little bit to the left (it looks like someone has taken it off and put it back on crooked)
    got any ideas of what it could be? it sounds like its stuffed
    EDIT:
    it has leaked before, because the liquid has been down and i can see on the mount of it,
    but now it doesnt seem to leak at all and its at full power steering fluid.
    2002 VX Executive S2 ex:Police
    Mar 2009
    Hi there by the sounds of what you have explained your first problem is your wheel alignment, this will be why your steering wheel is misaligned, and could well be the reason for your noise when turning in one direction, have your wheel alignment done, it will help at least and probably id any other suspension probs like worn tie rod ends bushes rubbers etc, once that is done you will be more the wiser have most issues sorted and if any probs remain you can deal with them specifically without the distraction of other sub-issues.
    Regards Chris
    callum_88's Avatar
    Nov 2008
    Salisbury Downs, SA
    i "apparently" got it done, but i dont know if i did or not. whats involved in a wheel alignment? is it just where they put weights on the wheels to align them?
    i wouldnt think that it would make a noise because of that :S
    callum_88's Avatar
    Nov 2008
    Salisbury Downs, SA
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by callum_88 View Post
    or am i thinking of wheel balancing....
    Yes, you are thinking wheel balance a wheel alignment consists of adjusting the angles of the wheels so that they are set to the car maker's specification. The purpose of these adjustments is to reduce wear on the tyres, and to ensure that vehicle-travel is straight and true.
    MY RIDE
    callum_88's Avatar
    Nov 2008
    Salisbury Downs, SA
    ah okay, well sounds like the **** heads that i took it to, didnt even touch it, and it cost me 50 bucks extra.
    would the wheel aliignment make my steering wheel properly aligned again at all? or is that something else i have to look at?
    also got any ideas about what i should do about this noise?
  1. Power Steering Noise
    By Huthy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-06-2010, 06:31 PM
  2. power steering making a strange nosie
    By controlled chaos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-03-2008, 06:10 PM
  3. power steering noise???
    By lilkel in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-05-2005, 06:36 PM
  4. power steering noise
    By dungbeetle46 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2005, 09:47 PM
  5. Power Steering Noise
    By vn_calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-02-2005, 07:57 PM
