Results 1 to 10 of 10
Thread: window switch LED
    VT Calais Supercharged V6
    Dec 2008
    Question window switch LED
    hey guys...
    my front electric windows switch in my vt calais dosnt light up the little white spot (the white ones in the back light up green with the lights are on but not the front) there are LEDs in them i opened it up to make sure but they have never worked since ive owned the car as well as the TRAC and Power button, just wonderin what i gotta do to get them to light up? I already checked fuses and stuff no problems there... Any ideas???
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Mines basically the same, Once they worked now they don't. It's a pain in the rear to replace these lights mine failed.
    Might be less of a hassle to just replace it with a aftermarket one, Cheap also just don't know the quality.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    trac and power buttons arnt too hard. Pull out the gear selector surround trim. and the sides of the centre console, then you should be able to unplug the power/trac control buttons and clip them out. They use the standard globes with green condoms. As for the window switches, id guess you would have to be good at soldering, or get a new switch lol. My rear passengers window switch has the led light out too
    VT V8 Calais
    Mar 2007
    I have had to replace my power window switch in my VT and the light for the drivers window has popped down into the switch
    Also I could only ever find a switch that has red lights, not green and i don't like how it looks in the car.
    50LTRv8
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    Quote Originally Posted by 50LTRv8 View Post
    they only come in green, if you want red you have to modify the leds.
    Dec 2008
    Does anyone have a guide or anything on how to change the LEDs ive just pulled it apart so i might as well change the LEDs to see what i can get maybe blue would look good... any idea how??
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    4 x 3mm LEDs ($5 max) r used in the main elec window switch block. U dont need 2 change the resistor inside unless its burnt out. snip the old LEDs legs and solder in the new LEDs making sure u have the correct polarity.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VT V8 Calais
    Mar 2007
    Thanks for that wrx
    Will take a look in a couple of weeks when I getthe VT back can't wait
    50LTRv8
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    VT
    Sep 2009
    Quote Originally Posted by Darkk_Calais View Post
    I havent had to replace the globes/LED's in the console yet..Ive seen the resistors, BUT I have replaced a rear door Globe..they ARE a 12Volt filament bulb...pick em up for a couple of bucks....they are used in audio equipmment as backlights... piss easy to replace...better than buyin a 2nd hand power switch for around $35...and the globe might blow in it anyway...want a different color..use nailpolish ...lol
  1. Power Window Switch
    By fitz_vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-04-2010, 10:56 AM
  2. window switch LED
    By Darkk_Calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-04-2009, 05:58 PM
  3. (SA) FS- VB-VL pwr window switch
    By GMHVLCT in forum Parts And Other Items For Sale
    Last Post: 17-10-2008, 06:55 PM
  4. VT power window switch
    By peter048 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2008, 09:28 PM
  5. VY Electric window switch into VL !!!!
    By Rogue-VL in forum Electrical Wiring / Questions
    Last Post: 11-07-2006, 06:51 AM
Tags for this Thread
