Results 1 to 6 of 6
Thread: overheating problem 1 hose hot 1 cold
    vt commodore
    Apr 2009
    Default overheating problem 1 hose hot 1 cold
    Hi ive got a 99' VT V6 and lately has been overheating the fans are working fine the coolant was abit dirty so i flushed the system and changed the thermostat as well but still overheating, the top hose which comes out of the motor gets really hot but the bottom stays cold.
    Im thinking the coolant isnt circulating into the motor when i flushed the radiator the water came out the bottom fine so its not blocked the only thing i could think of it being is the water pump anyone have a similar problem or know what it could be ????
    VQ Caprice II
    Aug 2006
    To quickly check the water pump,
    - remove the housing.
    - remove the thermostat (leave it out)
    - replace the housing fill with water.
    - run the engine, let it run for 10 min.
    - slowly open the radiator cap
    - rev the engine, should be seeing a flow of water.
    - no flow = dodgy water pump.
    - if the heat is now top and bottom hoses, could be a bad new thermostat
    replace and hopefully fix.
    hope this helps
    vt s s1
    Mar 2009
    The temp your feeling in the two hoses is normal.
    The top hose is hot because thats the hot water coming from your engine while the bottom hose is supplying the water which has been cooled by the radiator hense why its cooler.
    Are u losing any collant at all or pressure tested it?
    Anyway if ends up to be water pump will be fairly easy to replace.
    Goodluck
    commsirac is offline Banned
    vx
    Aug 2007
    Quote Originally Posted by vt s View Post
    Not in a car that is overheating.
    Does sound like a circulation problem.
    Could be water pump and/or radiator clogged.
    one test to see which is to turn the heater onto max heat and low fan speed and compare the temp of the water going in and out of the heater. If these hoses display the same trait, one hot, the other cold, chances are water pump has had it. If both relatively hot, maybe radiator clogged, but you say it drained easily, if it drains completely within 2-3 secs its good, over 5 secs, suspect.
    A restricted thermostat, maybe, but the problem was there before you changed and you have a brand new thermostat....could be installed back to front?
    1998 vt clubsport replica
    Dec 2008
    Perth, NOR
    i was going to say thermostat not functioning but you have changed it, but yes could be upside down and not opening properly.
    and yes before the thermostat opens top hose is hot and bottom cold and once it opens the both equalize
    vt berlina series 1
    Sep 2008
    you will probably find that about a 1/3 of your inlet tank is blocked with mud/scale . if your pump is fine then yank the radiator out and take it to a radiator shop for a clean , putting a hose through the radiator while its in the car does absolutely nothing , it may clear some dirty water but the hard dirt/scale will still be in the tubes
  1. Problem with broken radiator hose
    By LightningVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2011, 06:48 PM
  2. overheating problem
    By Eliminator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2009, 02:45 PM
  3. vs trans cooler hose problem
    By supaushh123 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2009, 07:39 AM
  4. vs overheating problem??
    By joshooaahh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-06-2008, 11:47 PM
  5. Air Con hose problem
    By Cairnsy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-01-2005, 01:23 AM
