Results 1 to 4 of 4
Thread: VX V6 Rear CV Driveshaft - HELP
    VR
    Dec 2008
    Default VX V6 Rear CV Driveshaft - HELP
    Hi all,
    Have a problem with my rear CV driveshaft. Got noisey, then lost drive.
    Has anyone done this repair or knows how to fix it?
    Any tips would help, as having a tough time removing it.
    Cheers, Pikey
    vt s s1
    Mar 2009
    Fairlyu easy to replace.
    There will be 6 bolts (from memory) connecting each end.
    I think you will need a torque bit if i remember correctly.
    Obviouslu car will be needed to be jacked up and just make sure if your replacing it that you put the new one in the right way, it should have a sticker on some sort of marking on it.
    Hopefully this helps i will say im that my experience was only with a vy.
    gsxrdan's Avatar
    gsxrdan is offline Has this got a turbo?!
    93 VP Excec; 95 II VR Equipe; 99 VT Exec
    Dec 2008
    adelaide, southish
    Hey ultra pikey, just done this on mine, after skinning three knuckles, i got my angle grinder and cut a 20mm piece off my 8mm hex key and stuck it in an 8mm socket - too easy!
    Sai Dai Tae Ma Damies!
    VR
    Dec 2008
    Cheers vt s and gsxrdan.
    Will give it a try this arvo.
    Pikey
  1. Driveshaft Wobble?
    By AdamAnt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-09-2010, 10:46 PM
  2. Rubber driveshaft boot
    By VTPREDATOR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-04-2007, 02:08 PM
  3. Vr Ss Driveshaft Help!
    By mark1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2006, 10:06 PM
  4. vp driveshaft repairs
    By half in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2005, 05:05 PM
