Results 1 to 13 of 13
Thread: VXII VY VZ Factory Siren Alarm Question Plz
    Aug 2008
    Default VXII VY VZ Factory Siren Alarm Question Plz
    I have a VXII (Series 2) Exec - these plus Vy & VZ came with the factory fitted alarm system which beeps a horn under the bonnet (firewall area) if a door or boot or bonnet is opened without first pressing the key fob "unlock" button.
    I would like to change the factory horn with something more noticeable / better. What brands are worth looking into? I know Jaycar sell some good sirens but I don't know which ones will work with the factory system. I noticed on the original siren only one wires goes into it. Any assistance or guidance here would be gr8. Cheers all and thanks for your help.
    Aug 2008
    Aug 2008
    Sorry people....last try on this matter. Anyone with any advise on this topic???
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Baldric is offline The BOSS
    VE GTS M6
    Dec 2003
    get a higher db alarm i think the std one works fine IMHO loud enough for people to notice. or if you like hook a air horn up to it it's just a simple switched circuit when vats detects a unauthorised entry (non button operated unlock atempt) it initiates power to the alarm circut arming the horn relay
    ___________________________________
    Car: 07 VE SSV 6LTR L98 A6
    Metalic Silver
    Aug 2008
    do you know of a siren type or make that can be plugged in? for example Jaycar sell a few siren types for car alarms; will any of these be suitable? cheers
    VE GTS M6
    Dec 2003
    anyone will do as it earths to chassis. the horn style on the commodores are a motorbike style. 2 pinouts only 1 is used (as it earths to frame via mounting)
    just make sure it has a simlar blade style pinout or you will need to make an adaptor lead up
    so like the good ole days... enny menny miney MOE !!
    Metalic Silver
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    is the Factory Siren Alarm an extra option coz i dont think i have one on my vx s2 s pac?
    VE GTS M6
    Dec 2003
    i think its on calais and upwards but on vy+ they were factory
    Metalic Silver
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    ive got a horn under the front bar and another horn just behind the strut tower on the left hand side with 1 wire hooked to it, im not sure what its for never herf it go off ever
    Aug 2008
    Series 2 onwards received factory alarm...from base model right to high level spec
    Aug 2008
    to hear the alarm...arm it by pressing lock button off remote twice so dead lock is activated. leave your drivers window down though. wait a few minutes and lean into your car and pop the bonnet release...alarm should now have gone off! try also the boot..unlock it but leave it in the down position. try using the same above sequence.
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    righto ill try it out thanks
  1. VXII Factory fitted alarm question
    By mourati in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-09-2009, 09:25 PM
  2. VS SS factory car alarm
    By crewsy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2009, 11:04 PM
  3. VT Berlina factory fitted alarm question
    By lordmuz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-04-2009, 05:21 PM
  4. Alarm siren installation
    By akcim13 in forum Electrical Wiring / Questions
    Last Post: 16-04-2006, 09:19 PM
  5. alarm siren installation
    Last Post: 15-04-2006, 08:33 PM
