Results 1 to 21 of 21
Thread: VT Calais Interior Light not working
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    Default VT Calais Interior Light not working
    hey guys,
    Just installed a VT calais interior light into my car. The main interior light goes on and off with the doors and evan when i push the buttons on the light the main light will come on but not the other 2? its completing teh circuit i know this because the other lights dont turn on.
    It says on the light that you need 12v8w globes i replace with 12v10w glove but no luck, 2 watts wouldent make a differnece.
    I know there is an eye crimp for the -ve on the 2 smaller ones and im 99% its getting earth...
    anyone goy any ideas?
    greekplaya is offline Wog On Wheels
    VT Executive S2 Olympic Ediiton
    Jan 2009
    Adelaide, SA
    Quote Originally Posted by SMIT View Post
    hey guys,
    I've just done the same thing and I think the wattage and the switches are linked somehow (i've got no real idea with electrics). I've got an LED as the main and standard halogens in the maps lights and all switches only turn on the main. My thinking is that the switches work by what is drawing the least power and turning that on which in my case is the main light.
    Hope that helps somehow, if anyone can let me know if i'm even close to being right that'd help too
    SMIT's Avatar
    Aug 2005
    Quote Originally Posted by greekplaya View Post
    weird ive got a LED as a main light and normal for the map reading light as well, might be the problem. anyone got any ideas?>
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    They won't work properly by just plugging them in, they need some modifications but I don't know how to do it.
    MY RIDE
    Jan 2009
    Adelaide, SA
    I'm fairly confident on the wiring side of things mine's perfect because when I put a standard halogen in the main as well all lights function as they should. So I think it must come down to the voltage of the LEDs???
    SMIT's Avatar
    Aug 2005
    Wait all your lights, light up? Evan the 2 map reading light when you use the normal globe?
    Jan 2009
    Adelaide, SA
    that's right, if i put a normal halogen globe in the main light all my lights function as they should, it's once i put the LED in that the map lights stop working
    SMIT's Avatar
    Aug 2005
    Ok well leds draw hardly any power compared to halogen, so its the resistors in the led festoon which are the problem.
    Jan 2009
    Adelaide, SA
    that's what I thought once I found that out so I've got some smaller LEDs on order for the map lights so once they rock up I'll put them in and if what I'm thinking is right all should function as it should
    SMIT's Avatar
    Aug 2005
    hey mate did you get the led lights in yet? is it working??
    Jan 2009
    Adelaide, SA
    still waiting on the smaller LEDs to arrive I'll make sure I post up once I know
    Jan 2009
    Adelaide, SA
    SMIT's Avatar
    Aug 2005
    Jan 2009
    Adelaide, SA
    Sweet, will order some, thanks for the info greekplaya.
    no problems glad i could help somebody else
  15. #15
    Gen 3 VT2 Berlina wagon
    Aug 2008
    I just bought a calais interior light for my vt aclaim and the main light works as it should, but if the main one is turned off, when you turn on 1 map light, the map light works but the main light turns on slightly, and when both map lights are on the main light lights up fully and the map lights are both very dull, like hardly even lit. Is this what happened with you guys? Mine has all normal globes in it, no LED's, so it has me stumped.
  16. #16
    Jan 2009
    Adelaide, SA
    Quote Originally Posted by VS_Wagon_Baby View Post
    I seem to remember that when I had halogens in my light that the main light would come on very dim but I can't remember whether I worked out how to stop it before I got all LEDs, might be worth trying a different globe maybe, are all the globes working?
  17. #17
    Aug 2008
    Yeah mate, all the globes work. I think there is power leaking through into the main light it seems. I might buy all new globes and see what happens, won;t cost too much. How much are LED's that would fit all 3 spots?
  18. #18
    Jan 2009
    Adelaide, SA
    Sorry mate can't remember what I ended up working out with the faint main I think I just ignored it since I was going all LEDs. Can't remember exactly on the LED pricing but I think it was somewhere between $5-$15.
  19. #19
    Aug 2008
    So there is no leaking with the LED's? That'd be good. Can you get blue LED's for the main light in there?
  20. #20
    Jan 2009
    Adelaide, SA
    everything functions as it should with all globes LEDs, you can put any colour you like so long as the globe fits, from memory I think its a 39mm festoon
  21. #21
    Aug 2008
    Thanks mate, appreciate it. Looks like i'm buying some LED's.
  1. VR Interior Light Not working
    By gobrien002 in forum Electrical Wiring / Questions
    Last Post: 05-01-2010, 09:31 PM
  2. Interior Light Not Working!!
    By nilprapai in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-02-2009, 03:19 PM
  3. Converting VR Executive light to a VR Calais interior light...
    By sverzijl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2006, 09:46 PM
  4. Interior light not working
    By COWSPUD in forum Electrical Wiring / Questions
    Last Post: 31-03-2006, 09:30 AM
  5. Interior Light Not Working
    By commielover in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2005, 11:51 AM
