Hi i have a vx commodore s pac, and have 19" rims on it.... i know its not legal but is there anyway of making them legal.. like getting the guards rolled or taking to an engeneer...
What would i have to do to make it legal?
if its scrubbing (you can hear it rubbing on the tyres or its making them wear really strange) you will have to ge the guards rolled, as long as they're not catching or rubbing or doing anything stupid, getting the car engineered will stop the police from beating down on you for it.
hope that helps![]()
Thanks does this mean i should have no problem getting the car insured if i have an engeneering certificate for the wheels?
how much on average for one of those anyway?
i thought as long as the tyre size is the same it didnt make any difference? is that just for Victoria? or is that completely false lol
its 2 inches difference but doesnt the s pac have 17's anyway ??
The law isnt 2 inches bigger.. thats a total myth and untrue
S packs come standard with 16s
This man speaks the truth! No 2" rule exists. The wheel cannot be more than 1" WIDER than that of wheels fitted to that model or series (so no wider than 9" for VT/VX).
Also rolling diameter laws exist but as long as you matched the profile of tyre to the 19" (should be 35) rim, it'll be legal.
Ok... the 2 inch rule is not a myth... but it was scrapped and updated a good few years ago now in Vic anyway... pretty sure all states have conformed as it was a ADR regulation so across the board... but get a modification guide and look it up to be safe.
Now... the new rule... in VIC anyway... it that you can only increase the width of the wheel by a max of 25mm and the overall diameter of the TYRE by upto 15mm.
So 19's are fine so long as you have the right profile tyre, the right load rating and it doesn't scrap or foul any of the body or suspension in its operation.
So if you're scrubbing you need the guards rolled.
I had 19's on my VX II S back in the day and i needed to roll only one guard... which was the Left rear guard... but I did have SSSL springs in it which didn't help.
Alot of people have fitted 19's without any issues so as long as you get the right width and offset... you should be sweet.
As i said... confirm the regulations in your state by getting your hands on a modification guide but if its the same rules as VIC, you're apples.
Hope that helps and good luck
