Hey guys am in need of some help. I installed a HD Clutch and solid flywheel last wednesday.
All was going ok and no problems to be had until bout2 days later when i would start the car there was a very noticeably ticking sound coming from under my feet.
For bout a day it would just happen when the car started then go as soon as i drove away.
However last night it didnt go away till after bout 15 minutes of driving.
It produces the sound in and out of gear.
I dont know how much it has to do with it bout last night when the sound stopped i was just coasting at round 60kph and help my foot on the clutch for few seconds and it stopped.
Not sure if coincedence.
Heres a vid of it if anyone could check it out it would be much appreciated.
Thanks
YouTube - VT sick
Sounds a bit like my vt did (but wasnt under my feet) ended up being the ignition leads & a leak in the exhaust manifold. The leak in the exthuast will cause a ticking noise when the engine is cold. After a few mins of driving it goes. If you installed the clutch though & the sounds coming from below im guessing it could be something to do with that, but dont know much about them.
dust cover. does it sound like tin not metal but tin.
thanks kego forgot bout that hopefully thats what it is.
If it happened to be that would it be alrite to have off for a while or not?
no don't take it off.it might not be sitting in there the right way. just move it and it should be all good mate.
glad to help you out mate.
