+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 33
Thread: Twin Turbo VT V6
    VT Twin Turbo
    Jun 2009
    Frankston
    Default Twin Turbo VT V6
    Model: 1999 VTII Executive
    Colour: Panther Mica
    Engine Type: Supercharged L67 V6 with Ecotec Heads (formaly Ecotec)
    Exhaust: 2.5 inch Lukey cat back currently (upgrading to custom built twin 3inch into single 4 inchwhen build is done)
    Gearbox: Auto is currently Stasge 2 shift kit but will be upgrade with stall convertor and built tough
    Brakes: HSV calipers on the front and slotted rotors all round
    Suspension: Ultra Low Kings springs and lowered gas struts and shocks to suit. Urathane front bushes inc sway bar and k frame
    Wheels/Tyres: Previously had Vx GTS (i think) as seen in picstures atm has nothing but stockies on it whilst bieng built
    Interior: Standard
    Stereo: Kenwood Head Unit with pioneer 6x9's in rear and stock fronts
    Engine Mods: Include a rebuilt L67 bottom end running a Come Racing billet turbo cam with 535 of lift. Heads had been rebuiolt and cleaned up with 3 angle valve jobs, Valve Springs will be getting replaced shortly to to meet the cams huge lift. Has Custom Turbo Manifolds (built by me) running 2 Garrett 500hp turbo's with 2 Turbosmart 38mm sleeper series wastegates, External oil feeds, Twin Throttle plenum, Custom Twin Intercoolers modified by me to fit the front of the car. Microtech ECU. Super6 injectors
    Fuel System: Stock pump as lift pump into 1.5lt surge tank to bosch 044 fuel pump. Paxton riseing rate reg into split feed to vs billet fuel rails split return to tank, 580cc RX7 injectors
    Power: Previous single turbo Setup made Around 230rwkw @ 10 psi New setup will hopefully be in the region of 320-350rwkw and 15-18 psi
    Other Mods:] Fiberglass VX Clupsport body kit, Air con Removed, Battery in boot, Alternator relocated, Catch can, Custom Made Rocker Covers
    Other Info: All Fabrication work is done by me persionally including all the Turbo Manifolds, Dump pipes, twin Throttles, catch cans all that stuff basically if its been modified ive done it myself. Car was previusly running a Single t4 turbo setup with tuned length pipes and front mount intercooler. I built that one myself aswell and it is currently for sale (PM Me if interested)
    A Big thanks to George at Proflow for use of his workshop and overseeing project and Pub247 for being a legend and guru on commodores and coming up with brillant ideas and for posting this thread
    FAT.36L's Avatar
    FAT.36L is offline 8,000RPM FTW!!! FAT.36L Hitchhiker
    Turbo S13 Onevia
    Sep 2008
    Maitland
    Sweet VT you have there mate, looks like alot of time and effort is going into it, the out come should be good
    FAT.36L NOW RIDING IMPORT
    Full 5spd Conversion For Sale PM me
    Pub247's Avatar
    Pub247 is offline Donating Member Pub247 W427 Pub247 W427 Pub247 W427
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Wow amazing about time you got on here even if i did have to do it all for you This car is unreal guys the amount of custom work hes done on it incredible especially for a guy that does it for a hobby not a job his work is as good as if not better than some business' do.
    EDIT a goood job by me i posted the thread and made a few errors ignore the double listing of injectors i didnt realise he's changed them since then
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    danja's Avatar
    danja is offline Swerves for gay koalas danja W427 danja W427 danja W427
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Nice looking car. Looks like a great job you've done on all the fabricated parts
    How/why did you end up with L36 heads on a L67 bottom-end?
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    I'll answer this one motor has been rebuilt for turbo setup hance the use of eco heads as using l67 manifold wasnt going to work with turbo setup. George at proflow built the motor
    VT Twin Turbo
    Jun 2009
    Frankston
    danja's Avatar
    Jan 2006
    Quote Originally Posted by Pub247 View Post
    Seems obvious now you say it
    So I gather the pistons/rods/crank etc are all the L67 boost-ready parts then? Sounds like a good setup
    holdenhero is offline Car idiot holdenhero Executive
    1998 VT
    Jan 2009
    Maroubra
    Hey mate top looking car, I'm considering getting mine sprayed black. I read the power output, but what kind of torque does it have? Have you ran it at the 1/4?
    PS. Pretty sure they are VY GTS rims, not VX.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by danja View Post
    Yep thats pretty much it theres no difference really between blocks
    Quote Originally Posted by VTEAZN View Post
    I wasn't sure when i posted the thread for him what rims they were i knew they were gts of some sort. New setup isnt complete yet but i'm sure when he takes it down the quarter he'll let people know. torque on the new setup should be beyond the 500nm mark
    I feel like a prick for answering all his replies
    1998 VT
    Jan 2009
    Maroubra
    VT Twin Turbo
    Jun 2009
    Frankston
    not to sure of the torque it put out i got it tuned for 10 psi and they just used the supercharged ecu tune so when i picted it up it had no dyno sheet but goarge from pro flow said a stock ecotec on 7psi projuce more torque than a ls1 on 10 psi are arond 220rwkw
    WH LS1 STATEO VR V6 STATEO & VR V6 BT1
    Nov 2007
    Adelaide-
    That looks like one tough monstar!!!! Love the ride you have there mate !!!
    $PIMPIE PAULIE$
    - GEN 3 BABY -
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Ah thats Better much easier using your username
    Grennan's Avatar
    Grennan is offline Justice League Grennan Senator Grennan Senator Grennan Senator
    Manual VX SS SII
    Mar 2007
    Glen Waverley, Victoria
  15. #15
    vs s2 acclaim
    Jun 2009
    HAMPTON PARK/VIC
    how much do you wont for the turbo setup ? and can i just put it onto my ecotec?
    haha v6 auto cherpn in 3rd
  16. #16
    hsvpunk's Avatar
    hsvpunk is offline volunteer firefighter hsvpunk Statesman
    vy ss II M6
    Jan 2007
    Mornington, Vic
    Mr Boostes.
    Very nice project you have going.
    Good luck with it.
    and bpw87, keep ya bullshit outa here.
    Make your own thread.
    dont worry, il start a ride thread soon.
  17. #17
    VT Twin Turbo
    Jun 2009
    Frankston
    um good point the turb on the kar in the pic is not the one im useing the exhaust housing is a 1.00 the ones im useing ar .68 hence the reason i can run two of them
    ______________________________________
    MY TWIN TURBO VT V6
  18. #18
    VT Twin Turbo
    Jun 2009
    Frankston
    thanks yours sounds awsome to its deferntly a lot of work but i think it will be worth it dipite the fact the some people say my 3.8 wont spool two turbos but i have a few tricks up my sleve and im comfident that i can make it run a number cood luck with everything go v6
    MY TWIN TURBO VT V6
  19. #19
    VT Twin Turbo
    Jun 2009
    Frankston
    the single to4 kit is on ebay at the till sunday if you got a vt upwards to vx/vy its a stright bolt on.
    MY TWIN TURBO VT V6
  20. #20
    idb
    idb is offline idb Executive
    holden vx s m5
    Nov 2008
    how much makea custom intake manifold with a single tb on front so i can hav a otrcai ??
  21. #21
    VT Twin Turbo
    Jun 2009
    Frankston
    do you mean you want want a cold air intake cuming in from the front of the engine to to create a stright itake path umm let me no what car/engine and ill let you no.
    MY TWIN TURBO VT V6
  22. #22
    Oct 2006
    hey m8 good on ya buddy for doing what your heart tells you to.yes every1 will say what a waiste of time do a v8 not a v6 but a v8 can be a hell of a lot more money and time to build so good luck with it m8 and take it from me the day you finish it and that first drive then you will know you made the write decision, i wish i could see the look on your face because thats the same look i get from my car as well. good luck m8.
  23. #23
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    We want updates i know you got some i spent 8 hours there yesterday helping you.
  24. #24
    VT Twin Turbo
    Jun 2009
    Frankston
    cheers mate dam straight i cant wait to drive the thing ive just spent the whole weekend working on it ill put up some pics soon
    MY TWIN TURBO VT V6
  25. #25
    ratzy's Avatar
    ratzy is offline It's Sedan Time ratzy Executive
    VZ exec on senator 18's
    Nov 2008
    canberra
    i am actually be in love with your car lol should be so sick when it is done man
+ Reply to Thread
  1. Super Charger, Twin Turbo Or Single Turbo On My Vx Need Suggestions
    By GMHG3N in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2009, 10:38 PM
  2. LS1 single turbo or twin turbo
    By weedo_86 in forum LSx Development and Modification
    Last Post: 05-12-2008, 03:08 PM
  3. 383ci single turbo or twin turbo??
    By adictd in forum V8 Development and Modification
    Last Post: 04-12-2008, 07:49 PM
  4. Twin Turbo better than Single Turbo?
    By Blue-Chip in forum V6 Development And Modification
    Last Post: 23-12-2005, 04:38 PM
  5. twin turbo ecotec, turbo selection?
    By jenkos_vl in forum V6 Development And Modification
    Last Post: 08-11-2005, 12:03 PM
