Results 1 to 18 of 18
Thread: My 1999 VT Berlina - Holden_4aw_lyfe
    holden_4aw_lyfe's Avatar
    holden_4aw_lyfe is offline Tsu Tsu Tsu Tsu
    Twin Turbo Stroked 4.2LT VT Berlina
    Feb 2009
    Default My 1999 VT Berlina - Holden_4aw_lyfe
    **OLD, NEW MORE REVISED DETAILS AND PICTURES COMING SOON!!**
    My 1997 VT Berlina Series 1 V6 3.8
    SAND PEARL MK2.
    Engine/Transmission:
    - Block Decked, Honed, Line Bored, Balanced and Blueprinted W/ Compression 8.3.1
    - Pacemaker Extractors
    - 2.5" Custom Stright Exhaust With Dual Exhaust Chrome Tip
    - Metalcat High Flow Cat 200CPSI
    - Hedman Muffler 24" Straight
    - Mace Engineering Custom Plenum Spacer 17mm
    - Mace Engineering Custom Cold Air Inlet Manifold Spacer 25mm
    - Mace Engineering Custom Bored Out And Polished Throttle Body 69mm
    - Mace Engineering Custom 85mm Mass Airflow Meter
    - Yella Terra 1.7.1 Ultra Lite Roller Rockers
    - 4" Pod Filter
    - US Motor Works Professional Series Water Pump
    - Custom Ported & Polished Plenum Cover
    - Custom Ported & Polished Manifold
    - Custom Polished Fuel Rails
    - Transgo Stage 2 Shift Kit
    - New Transmission
    - Corvette Servo
    - Billet Rocker Cap
    - Custom Polished Fuse Cover
    - Top Gun 10mm Ignition Leads
    - MSD Ignition 8224 Coil Packs
    - B&M Line Locking System
    - Fabricated Aluminium Power Steering Reserviour
    - Polished Rocker Covers
    - Fabricated Polished Aluminium Fuse Box Cover
    - Fabricated Billet Rocker Cover Cap
    - Fabricated Polished Aluminium Strut Tops
    - Fabricated Polished Aluminium ABS Cover
    - Fabricated Cruise Control Cover
    - 8" LSD 28 Spline Diff With Borg Warner 3.9" Diff Gears
    - Detriot Tru Track Lockup System
    - COMP Cams Agressive Stage 3 Cam
    - C.O.M.E Racing 4.2L Stroker Kit W/ "H" Beam Conrods
    - Rollmaster Double Row Timing Chain
    - Cast Nodular Iron Crank
    - Powerbond 5% SFI Overdrive Harmonic Balancer
    - Mace Engineering Ported Aluminium Heads
    - Custom Oil Pump
    - King Bearing Kit
    - 3500 RPM TCL Strengthened High Stall Converter
    - ARP Head Stud Bolt Kit
    - ARP Mains Stud Bolt Kit
    - Crow Cams Roller Lifters
    - Bosch Platinum Fusion Spark Plugs
    - ARP Flex Plate Bolts
    - K&N High Performance Oil Filter
    - Turbosmart FPR800 Fuel Regulator
    - Clarko's Aluminium Pulley's
    - ACL Race Gasket Set
    - 40 Thou Cometic Race Head Gaskets
    - Custom Turbo Manifolds
    - 2x Garrett T28 Turbos
    - 600x300x76 Intercooler With Pipes, Clamps and Silicone Bends
    - Boost Controller
    - Turbosmart Supersonic Blow Off Valve x2
    - Stainless Braided Water Lines
    - Oil Lines
    - TTT Performance Engineering Engine Mounts
    - 80lb Siemens Deka Injectors
    - ASR Street Comp High Volume Custom Oil Pan
    - 4 Core NT Perofmrance Aluminium Radiator
    - Aircon Deleted
    - Silicone Radiator Hoses
    Suspension:
    - King Spring SSL Suspension SOON TO HAVE HSD COILOVERS
    Interior/ Exterior:
    - Custom Headlights Monaro Look-A-Like
    - 6000k Xenon HID Conversion Kit
    - 19" B&W Wheels
    - VX SS Gunmetal Grey Dash
    - VZ SS Chrome Air Vents
    - Full LED Blue Dash Conversion
    - Full Blue LED Interior Lighting Conversion
    - 4x Under Seat Blue LED's
    - Full White LED's in Number Plate And Wipers
    - Clear White Reverse Lights
    - Genuine HSV Custom Painted Rear Boot Garnish Tungsten Mica
    - Chrome Bonnet Struts
    - Full Under Car Neons
    Stereo:
    - 2X Rockford Fosgate P3D212 12" Subs
    - Rockford Fosgate T1500 Power Mono Block Amp
    - Rockford Fosgate T400 Power Amp
    - MB Quart 6" Splits At Front
    - German Maestro Discus Series 6X9 Rear
    - Optima Yellowtop Dry-Cell Battery
    - Eclipse AVN726EA Head Unit
    - Mitsubishi 120Amp Alternator
    - Rockford Fosgate 10 Farad Capacitor
    NEW PICS OF FINAL PRODUCT SOON
    Sphinx's Avatar
    Sphinx is offline O.G.
    VX Calais II LS1
    Aug 2005
    Pakky
    Looks pretty good. But I'd be removing all the badges except for the HSV on the rear garnish as it looks odd with the HSV one right below the Holden one. Much drone with the 3.5 inch exhaust? Oh, you could do with a few more unit stickers too
    The Calais
    Sleeper Club
    hsvpunk's Avatar
    hsvpunk is offline volunteer firefighter
    vy ss II M6
    Jan 2007
    Mornington, Vic
    hmm looks alright. I looked at a gen3 in this colour a while ago.
    Unit... right.....
    As mr sphinx has said.
    Also, where in melb ya from?
    dont worry, il start a ride thread soon.
    Feb 2009
    haha im a big UNIT fan lol. yeh all the badges are gonna be removed, its getting a respray and all the dints knocked out of it so when i get that done ill remove em then. Im from Sunbury lol yehhh the exhaust sounds good, its needs to sound deeper tho haha. When i put the pacemakers in and the chip itll sound and go better well should haha
    Vt Executive
    Jul 2009
    does it lose any power through the 3.5" because you would think so being that large? would sound tough though
    VX commo 02's Avatar
    VX commo 02 is offline purchasing S/C VX!!!!
    VX Commodore S2 & VX S/C S pack
    Sep 2009
    Adelaide, SA
    Vt Clubsport
    May 2009
    cery nice. id go with debadging entire car except for the HSV badge too. tint windows. and personally if you have the time/money. i think chrome windows/front mirrors/door handels would looks absolutely awesome!!
    Feb 2009
    it does sound good, its got a clean note to it...i was actually suprised when i first heard it lol. the whole car is going to be chrome, the theme is chrome so hopefully a lot of it will go on. Just bought a 6000K Xenon kit for it and custom aftermarket headlights. should look sick :P
    jarrad09 is offline Vt 5sp S
    Vt S Manual V6
    Jun 2009
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    looks nice !
    But , IMO.. I dont like the Unit Stickers
    pics of engine bay pleassssseee???
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    Feb 2009
    hopefully a stage 3 chip haha, see what chip control say...i have to get a dyno tune too though so ill see what happens. The unit stickers are coming off lol looks a bit gay lol. ill post pics up tomorrow asap for everyone to see new pacemakers look tuff
    VN Executive V6
    Jun 2008
    The car is sick, lol edit 2.5 inch but dead serious it is the crispis V6 ive heard to date. sounds tough. and those aftermarket monaro looking headlights are awesome. but VNs will always be better HAHA
    CHUNT
    Subaru Impreza MY05 WRX STi
    Mar 2009
    Sunbury
    Looking good! Looks even better in person. ^_^
    Gotta agree with doyab.. Best sounding V6 I've ever heard..
    VN Executive V6
    Jun 2008
    Feb 2009
  16. #16
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Don't think you need to bump your ride thread mate. LOL
    Anyway, post some pics
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
  17. #17
    VT Calais International S/C
    Nov 2009
    Fuuck, that engine bay is insane! I thought I was a bad ass driving a supercharged car on my P's.
    How do you get around that?
  18. #18
    Feb 2009
    haha i dont man i drive another turbo around haha....Skyline R33GTS-T
    Don't Knock My Turbo Lag, It Gives Your V8 A Chance
  1. My 1999 vt s XAC-209
    By kindo in forum VT - VX - VU - WH - V2
    Last Post: 11-04-2011, 12:43 AM
  2. 1999 VT Berlina - Build Thread
    By riggaz in forum VT - VX - VU - WH - V2
    Last Post: 26-06-2009, 02:33 PM
  3. 1999 Gts
    By tdog in forum General
    Last Post: 05-12-2008, 03:05 PM
  4. My 1999 Vs Ute
    By Rexy_Vs in forum VR - VS
    Last Post: 19-11-2008, 12:37 PM
  5. My 1999 Vt Ss 5l
    By jamesl_VTSS in forum VT - VX - VU - WH - V2
    Last Post: 22-10-2008, 04:02 PM
