Current Ride
2000 Holden VTII Commodore S PAK Supercharged ( L67 )
Engine Hardware
L67 3.8L Supercharged
Transmission
4-spd Auto
Auto transmission cooler
Engine Modifications
M90 Supercharger (factory)
Aunger OTR CAI (over the radiator)
K&N panel air filter
2.5" high flow metal cat
10 PSI mace engineering pulley kit ( 11 PSI hopefully coming soon)
ZZ Performance 10.3mm Leads
NGK iridium spark plugs
Extra Large K & N oil filter
Driveline Modifications
Standard LSD
Brake Modifications
standard twin pot brake calipers
Suspension Modifications
FE2 Holden sports suspension
Wheels & Tyre Modifications
Sock 16 x 7 rims
Body Modifications
De badged rear end
Holden SS kit
Interior Modifications
Calibra Boost Gauges
In Car Entertainment
Pioneer 6 cd stacker
8GB ipod
POWER: ? will wait till i have most of the work done and then get it dynoed
The car is fairly standard atm but will be doing a bit of engine work in the next month dont plan to do any body work as i like the car the way it is.
Standard intake:
Aunger CAI:
new pulley and some higher ratio rollers will make it a tidy little sleeper.
Nice clean streeter you have there BJ31OS
As for your boost up grade kit it should be sent off on Monday, for which you'll be very happy with once installed![]()
hey man nice clean ride, Im keen to see power figures tho, hope you get it dyno'd after the 10pis kits on. should put the VT/X SS wheels under it and de-baged it.
plenty of potential there mate could even leave it as a sleeper n smoke off some xr8s lol
Keeping the car a sleeper.
also have an exhaust on the way very soon
invest in some diff gears makes a big difference but if ts your daily i wouldnt reccomend going over 3.7's .
Well the spark plugs and K&N oil filter have arrived i ended up getting a oil filter that is 1 inch longer than normal,
will be heading out on sunday to get oil and diff oil then the car will be in the shop for a full service.![]()
Double post
looks good mate, those leads do look pretty chunky, i like em, do they do anything response wise???
TBH i haven't really driven the car much since they got put on but the engine deffiantley runs much smoother
General shit tires and the wrong load rating will make that noise.
Well just picked up a set of pacemaker headers and a Yella Terra intake from Koo intake will be pu on tomorrow headers will be on later on in the year
