Page 1 of 7 12345 ... LastLast
Results 1 to 25 of 157
Like Tree7Likes
Thread: My 6L, cammed, manual WH2
    WHII Statesman
    Sep 2006
    Geelong, VIC
    Default My 6.4L, turbo, cammed, manual WH2
    (Updated (13/07/11)
    Hey guys,
    Here are some details of my ride! It's abit unusual for a Stato, but I love it
    Car: 2002 WHII Statesman
    Colour: Blue
    Engine Type: Originally an LS1...
    Engine Mods:
    - VZ L76 6-litre engine swap
    - 3.825" stroker crank (390ci)
    - CP-Carillo 4.030" forged pistons with -15cc dish
    - Callies 6.125" H-beam rods
    - LS9 headgaskets
    - ARP everything
    - Borg Warner S400SX3 Turbo (75mm, 1.10AR)
    - NJCCorp custom reverse-split turbo cam
    - Lunati dual valve springs
    - Morel link-bar lifters
    - Comp 7.375" hardened pushrods
    - Powerbond 25% Underdrive pulley
    - 60LB injectors
    - SX fuel pressure regulator
    - 3L surge tank with dual Bosch 044 fuel pumps
    - Elite engineering catch-can
    Power kw/hp: 442.4rwkw
    Torque ft-lbs/nm: 1220nm
    Brakes: Harrop 'Extreme' brake package
    Exhaust: Custom Single 3.5" exhaust, ballistic 5" body racing cat, 100cpsi
    Diff:
    - Eaton TrueTrac LSD centre
    - 3.73:1 diff gears
    - Harrop high volume diff cover
    Gearbox/Transmission:
    - T56 conversion
    - Tex Z-grip clutch
    - GM Motorsport RipShift 'Race'
    - Braided clutch line
    - Remote bleeder
    Suspension:
    - Pedders coilover with Bilstein B6 inserts
    - Koni Yellow rear shocks
    - Eibach 350LB linear rate front springs
    - Eibach 600LB linear rate rear springs
    - Nolathane poly rear subframe mounts
    - Nolathane poly radius rod bushes
    - SuperPro 4-point camber kit
    Wheels & Tyres:
    - HSV VZ R8 19" wheels
    - Nitto NT05 Street Legal Semi-slicks (245/35/19)
    Interior: Stock leather
    Stereo:
    - Alpine IVA-W202E headunit
    - Alpine PXA-H701 digital processor
    - Exodus Anarchy 6.5" woofers
    - Scanspeak Illuminator D3004/6020-00 tweeters
    - RE XXX '05 12" subwoofer
    - Diamond Audio D7104 4-channel amp
    - Diamond Audio D7152 2-channel amp
    - Soundstream 'The Tarantula' 1-channel amp
    fkford is offline Love The Beast!
    VS exec S2
    Mar 2009
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    Awsome stato man,
    Any future plans ?
    Love it.
    Quote Originally Posted by minux
    HAHAAHHAHAHAHAHAHHAHAHAHAHHAH
    Wanker.
    WHII Statesman
    Sep 2006
    Geelong, VIC
    Thanks guys. Not sure on future plans, I've got a project car I'm trying to dedicate some money towards, so the Stato will hopefully be left alone for awhile.
    ducker85's Avatar
    ducker85 is offline Calais man
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    WHII Statesman
    Sep 2006
    Geelong, VIC
    I haven't had it on the dyno since I installed the cam. The last dyno was 268.5rwkw, but that was with the 6L unopened.
    redcv6's Avatar
    redcv6 is offline supercharged intercooled
    vy ss ute, diesel landcruiser 100s, hq panel van
    Aug 2006
    Ringwood
    VN Calais 5L
    Dec 2006
    love the stato man, everytime i've seen it its had something new, first the manual, then the 6L, now the cam haha
    WHII Statesman
    Sep 2006
    Geelong, VIC
    vx l67/v8 lpg vq
    Jan 2010
    mate duno if u remember me but i met u breifly for the first time at the meet on friday night
    your car is awesome..i love it
    i was in my silver vx tho its not as good as yours haha..feel free to check my thread and chuck us a comment id like that mate
    whats your other project btw??
    cheers
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    Dude what was the dyno read out of that run ?
    Wanker.
    WHII Statesman
    Sep 2006
    Geelong, VIC
    Quote Originally Posted by silvervx View Post
    cheers
    Thanks mate, will do. The other project involves a lot of horsepower in a nice car from Sweden
    Quote Originally Posted by VN-Commonwhore View Post
    That dyno run was prior to the cam getting installed. 92mm throttle, 1-7/8" extractors, twin 3" exhaust and a tune = 268.5rwkw
    WHII Statesman
    Sep 2006
    Geelong, VIC
    06vzcalais is offline Donating Member
    Aug 2009
  15. #15
    benjamino's Avatar
    benjamino is offline needing some more undies
    VX SS 6spd + 7psi
    May 2008
    The Sticks, WA
    top lookin car mate, 6l manual aswel uve got one of a kind there!
    great photos aswel.
    verrryyy nice
    450 good reasons to just power on
    yeaahhh
  16. #16
    WHII Statesman
    Sep 2006
    Geelong, VIC
  17. #17
    carless for now
    Feb 2007
    perth,Western Australia
  18. #18
    WHII Statesman
    Sep 2006
    Geelong, VIC
    Yeah it does visit the quarter occasionally, but I haven't been able to get a decent time out of it yet.
    In its current setup I've raced it twice, but I screwed up each run a different way, so there time isn't very impressive.
    First run: Perfect launch, 1.7 second 60ft. Then I messed up the 1-2 shift and hit the limiter. I then hit the limiter on the 2-3 shift again, and missed 3rd gear. Took 2 attempts to get it into 3rd, and then hit the limiter on the 3-4 shift again! Did a 13.1 @ 108mph that run, so heaps of room for improvement.
    Second run: Shithouse launch. 2.7 second 60ft with alot of wheelspin. Perfected every shift though. 13.1 again, but at 114mph.
    Looking at the info for both these runs, a low 12 shouldn't be a drama, but I haven't got it that fast yet.
  19. #19
    carless for now
    Feb 2007
    doesnt the rip shifter help getting in to third without missing? easy 12's though would you say the car would be near 2000kg's with the audio stuff in it?
  20. #20
    WHII Statesman
    Sep 2006
    Geelong, VIC
    It does help, but the T-56 is a fussy bitch. If you hit the limiter, the gear doesn't want to engage properly even though the ripshifter has lined it up nicely.
    The car is 2088kg with the audio gear, but i ditch the amps and sub when running down the quarter, which saves about 100kg.
  21. #21
    carless for now
    Feb 2007
    are you using slicks? even with 2 tonnes it can still pull a 12 easy. nice
  22. #22
    WHII Statesman
    Sep 2006
    Geelong, VIC
  23. #23
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    sweet looking ride mate, and plenty of power too, quickest time i ran was only a 13.1 and that was with no ****ups haha
    Going where no late model stato/caprice has gone before.... GAME ON!!
  24. #24
    car
    Jul 2006
    greensy, melb
    nice nem, didnt realize you had a thread up, when i started reading the thread i was thinking 'hey someone else has done it too' lol, anyways looking good as always
    "A life lived in fear is a life half lived"
  25. #25
    ewt
    ewt is offline
    VT Wagon & VZ Berlina
    Mar 2010
    Sunbury, VIC 3429
    Max Power is at 6500rpm? Isn't that where the limiter is?
    Anyways, like your Stato mate. Are you looking down the path of Forced Induction?
    Josh.
  1. Cammed BLACKVE SS ute
    By BLACK-VE in forum VE - WM
    Last Post: 19-12-2011, 11:58 AM
  2. VP SS Manual, Cammed
    By Snakes-Calais in forum VN - VP - VG - VQ
    Last Post: 15-03-2010, 12:21 AM
  3. [SA] Cammed VS 5.0L BT1
    By ChargedBT1 in forum Vehicles For Sale
    Last Post: 11-10-2009, 09:58 PM
  4. Cammed v6 exhaust
    By GTP 85 in forum V6 Development And Modification
    Last Post: 21-10-2008, 12:45 PM
