Results 1 to 2 of 2
Thread: Imlikn wh statesman blown v6 stroker
    WH S/C STROKED CAMMED N COOLED ST80
    Jan 2009
    Default Imlikn wh statesman blown v6 stroker
    hi all thought it'd be about time i posted some pics of my stato
    Model: 2001 WH Statesman
    Colour: Storm grey
    Engine Type: L67 Supercharged 4.2l stroker.
    Engine Mods:
    factory block, acid bathed, crack tested, blueprinted
    custom forged ARIAS pistons from the U.S
    PRO STROKE billet stroker crank 4.2
    Roll Master Double row timing chain
    Ported and polished yella terra heads
    Cometic copper gaskets
    Ls1 style conical springs
    Larger valves
    1.6:1 Yella terra roller rockers
    Crow push rods
    Hydraulic lifters
    Clive custom grind cam
    factory M90 supercharger
    BYE/ZZP 8 rib supercharger pulley kit
    BYE/ZZP 2.8" pulley
    Ported throttle body
    Powerbond 5% overdrive balancer
    standard fuel rails
    Reconditioned factory injectors
    new alloy radiator
    FIT air to air adaptor plate
    FIT 600x400 intercooler
    FIT stainless steel intercooler piping
    Factory Coil packs
    Low temp NGK spark plugs Bpr6efs-15
    Power: 200rwkW safe tune
    Exhaust: 1 ¾” pacemaker extractors into a 3” straight through exhaust hi flow cats with dual 3inch chrome dump pipes.
    Gearbox: Rebuilt and strengthened with corvette servo piston 2500 dominator hi stall
    Diff: lsd centre 3.9 gears
    Brakes: Stock with bendex pads
    Suspension: Heavy duty sway bar link pins, GT front gas struts, Munroe gas shocks Rear, SSL king springs front, custom Auora Damn lows rear.
    Wheels/Tyres: 20" Feretti wheels with 225/35/R20 Sport one tyres.
    Interior: full custom CREAM leather interior including re foamed and trimmed front and rear seats, door panels upper and lower, fuse cover and glove box, console lid and handbrake cover, calais woodgrain shifter piece and woodgrain shifter. boost gauge mounted in fuse cover.
    Body Mods: custom Boss bonnet bulge grafted in, VZ ss flutes, gaurds pumped to allow 275 wide tyres, Caprice grill with custom blown badge, grange rear spoiler, S2 number plate surround,Caprice chrome door handles, Altezza headlights (chrome), grey strips colour coded storm grey, Dark window tint.
    Stereo: twin kicker 12"s in the boot with kicker amp, kenwood head unit.(next on the agenda)
    Others: Full set of custom billet caps to dress up the engine bay.
    Build Period: close to 3 years
    Cost: losing count
    Future mods: contemplating either Whipple 2.9l unit
    or if the compression ratio is suitable, remove the charger and Turbo it
    let us know what ya's think cheers Mat
    Attached Thumbnails Attached Thumbnails Imlikn wh statesman blown v6 stroker-img_8697.jpg   Imlikn wh statesman blown v6 stroker-img_8679.jpg   Imlikn wh statesman blown v6 stroker-dsc01271-1-.jpg
    IMLIKN you know you are
    VT II Berlina
    Mar 2010
    i love that first photo, you need some bags brotha... ya heeeaaarrrddd!!!
  1. 355 or 383 stroker????
    By Zeussy in forum V8 Development and Modification
    Last Post: 25-04-2010, 11:52 AM
  2. Blown stroker?
    By Shuttsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-04-2010, 11:36 AM
  3. vs statesman blown bulb warning light
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2007, 07:22 PM
  4. Stroker.
    By Genesis in forum V8 Development and Modification
    Last Post: 17-10-2005, 10:08 PM
