Results 1 to 10 of 10
Thread: Starting on my VT II Executive
    VT II executive V6
    Nov 2011
    Default Starting on my VT II Executive
    took this car off my mum
    bought a set of VT SS rims + almost new tyres for 250
    chucked new brake rotors and pads on as well
    Attached Thumbnails Attached Thumbnails Starting on my VT II Executive-377846_317654794912424_100000037171146_1353659_531901897_n.jpg
    purrrrrr
    VT II executive V6
    Nov 2011
    I'm thinking of putting in a pod filter
    does anyone have any opinions about what's better? Panel or pod?
    purrrrrr
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by fossburger View Post
    Unless you're boxing the pod (as in, MACE box), panel 100% of the way..
    If you just put a pod in it will suck in hot air from the engine bay and reduce power..
    If you are keeping the stock airbox, K&N panel..
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    VT II executive V6
    Nov 2011
    ok, fair enough.. but what if i were to extend the piping of the pod so it sits down near the bottom of the engine bay where all the air from under the car is? would that work or would the extended piping cause some sort of problem (ie, lack of air..etc)
    EDIT: on second thought, i guess that would be a bad idea as it would suck in water from the road
    purrrrrr
    VT II executive V6
    Nov 2011
    I've decided on going the Pod Filter because the small increase in power isnt an issue for me, i can live without it
    the pod looks and sounds better and that's good enough for me
    i just need the car lowered and an exhaust chucked on it
    purrrrrr
    VT Calais
    Aug 2011
    Ballarat
    I think the first thing you should do is lower it, it could double as a monster truck at that height :P
    VT II executive V6
    Nov 2011
    haha yeh that's true, but really i don't mind it... i definitely am going to lower it, but it's not the number1 priority
    i like how you can see the tyres from behind the car and because the SS rims are wider than stock, it makes it look sorta 'drag-spec' :P
    purrrrrr
    vy calais
    Aug 2011
    bachusmarsh
    yo would get a power gain from a pod warm air wont affect much coz it not a high powered moter
    '97 VT Exec
    Feb 2010
    Croydon Hills, Melbourne
    chuck some fat 255's on the back like me and it looks sick haha
    good start mate similar to what i started with. How do you think the new rotors/pads are, feel any different?
    VT II executive V6
    Nov 2011
    it feels SOO much better with the new brakes... i replaced them because the pads had been left in for way too long, it was basically the metal plate on the back of the pad grinding away at the rotor
    now it's all smooth and amaaazing
    and about the 255s on the back, ahaha that would be sick! can you post a pic of your car from the back so you can see the fattness of the tyres?
    235s is fat enough for a v6 anyway :P
    purrrrrr
  1. VS Executive wagon not starting and only code is 92
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2011, 07:40 PM
  2. VT Executive Series 2 Starting problem
    By GIARU5 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-12-2009, 09:31 PM
  3. car not starting at all
    By crazstaat in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2009, 05:40 PM
  4. Vn Not Starting.
    By K1ND3R in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2009, 09:18 PM
  5. vn not starting
    By vn4play in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-11-2005, 05:30 PM
