Nut Kracker's 1997 VT SS (Lots of Pictures)
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Thought it was time to put up a thread......
Engine By ChipControl
1997 VT SS
5 Litre 195i
Custom aluminium port matched high flow intake manifold (Approx. 2000 cfm).
Mafless tuned VCM OTR cold air intake.
Custom twin 60 mm throttle body.
Heads ported and polished.
Yella Terra roller rockers and heavy duty double valve springs.
Crane 888241 roller camshaft.
Pacemaker extractors.
2 ½ inch twin cat back exhaust system with high flow catalytic converters.
Polished aluminium valve covers.
Billet clutch master cylinder.
Chrome bonnet struts.
Various polished aluminium and chrome components.
Rev limiter @ 6200 rpm
341 HP @ flywheel (255 Kw)
275 RW-HP (203.7 Kw)
Exterior
CSA Typhoon 17x8in wheels.
VX rear boot garnish.
Gold badges.
Custom mesh grill with UV Leds .
Altezza head and tail lights.
Interior and Trim
Door trims, glove box, fuse cover, steering wheel, side console trim and console lid covered with Italian leather inserts.
Custom blue crazed dash and centre console.
Centre console lights.
White/blue instrument lights.
Din mounted temperature and voltage gauges.
Clarion VZ401A touch screen head unit.
Alpine 'SPS' series front and rear speakers. Front splits.
Fli Trap 12 inch 1200 watt sub woofer.
uniacidz
Harden the Frak Up
Sideneee
VE Berlina
Lol like finally
Looks good
Sent via HTC Velocity + [HolicsROM v1.3] [SWEEP2WAKE]
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Thanks y'all for those kind words.
Twas a labour of love (?) over the years, adding, modifying and removing bits.
My daughter and I installed the door and the other trim bits in the summer of 2012. 40+ degree day, whoa.
15 minutes outside, 30 minutes back inside with the air con on full, then back at it. What was I thinking?
The rest of the accessories where install over time when funds allowed. Most purchased off eBay.
I'm happy with it.....until I get tired of something and change it.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
I had a different idea as to how to install the console gauges.
Dunno if anyone's done it this way or not. It wasn't hard and worked out really well, for me anyway.
I just used some 3mm MDF, it's easy to cut and shape and attached it to the console insert. Although 2mm would have been better, if it's available.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
:bang: Ahhhh great.......Someone pulled too hard on the passenger's side seat pocket and broke a clip.
Got the s##ts and ripped the whole thing off. Now I'm up for $60 or more to replace the damn thing.
Any one so much's sneezes near it, I'll bust their balls :banstick:
