Results 1 to 2 of 2
Thread: Removing Strips off side off car!
    2002 VX II Commodore Executive
    Aug 2007
    Default Removing Strips off side off car!
    Hey there. I have a VX II Executive, and as all Executive's do, this particular car has black strips on all four doors (in other models, such as acclaims - they are the colour of the car), as well as having them on to extra panels at the front of the car. I'll post some pictures below.
    <img src = "http://i20.photobucket.com/albums/b215/finnbe/untitled-3.jpg"?>
    Basically when these side strips are ripped off, two substances remain which were used to stick these strips on to the car. The first is a grey like double sided tape which is able to be removed by just peeling it off.
    It is the second substance that I am having trouble removing. It is a black silicon like substance, which is definetly water proof, used for outdoors, and goes extremely hard when set.
    I have tried removing this black stuff using heat (a hairdryer), which does not work because it also peels of the paint behind the substance. I have also tried cutting it off, and then using a scourer to clean it nicely, the problem is these cuts have to be made with precision, and one small mistake results in a nice cut in the paint behind. And after a hundred cuts or so, this seems a bit difficult.
    Here's a few pics of it (I've combined it into one pic).
    <img src = "http://i20.photobucket.com/albums/b215/finnbe/P1010129.jpg">
    So I am appealing to anyone that has any idea how to remove these strips!! Please suggest anything that you might no of!!!
    vy_storm's Avatar
    vy_storm is offline just another moderator...
    VE Calais V 6L
    May 2005
    the burbs of Adelaide
    Just the one thread will do thanks.
    How to Remove Side Strips on VT/VX etc?
  1. Removing Black Rubber Side Strips
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-12-2010, 02:36 PM
  2. Removing side bump strips on VSII????
    By mickoss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2009, 08:25 PM
  3. Removing Strips off side off car!
    By finnbe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-08-2007, 11:12 PM
  4. Removing door side strips
    By karlos_1984 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2007, 10:40 AM
  5. side strips
    By ad45 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2006, 10:58 AM
