g'day peoples looked back 3 pages but could not find a thread regarding clutches. Sorry to start new thread !!
After 150,000km minor service every 5k major every 10k and pretty much
Picture perfect ute but my clutch is starting to slip now so an aftermarket
Clutch is the go, it's also comes to my attension that you will need a new flywheel aswell so I was looking at a VY excedy HD clutch as a replacement
I'm calling repco and autobarn for a quote I'll let you know tommorrow peoples
Of the $$ involved I'll even get the website and prodct code
Rik
EXCEDY SPORTS TUFF HD CLUTCH/FLYWHEEL. code: EAP-GMK-7353FWHDB
This model is two up from the OEM they produce....
http://www.exedy.com.au/SpecSheet.as...eetRowId=36437
$$$$ ill let you know tommorrow
Ps. Does anyone know any other manufactures that do performance clutches ???
RIK....
Spoke to simon at chatswood and he said $1460 but even he was supprised
And said hang on ..... Computer click click click type type LOL ok $1200 so
I think that is not a bad price ??? Anyone he is going to get back to me if it
Will fit but I think I made a mastake and only HD button only fits next model up
Speaking with him tommorrow again I'll find out for sure...
So if I stuff the excedy clutch next time around flywheel is not needed ?? Only clutch??
Is this correct ??!!
Rik
Gday peoples.....
Spoke to Simon Again at repco the Excedy HD clutch with Ridged Flywheel is $1200... Because of the mass flywheel it cannot be machined and holden costs a bomb to replace clutch/mass flywheel.
After talking to my ace mechanic he said everyone is getting away from mass flywheels and getting ridged flytwheels so they can be machined.
Now when you blow a clutch you just machine flywheel instread replacing the mass flywheel and clutch aswell...
Asked my mechanic if you can get it cheaper for me at his clutch place quoted the same ammount $1200. just was not sure if repco had a markup..
Love answering my own questions lol
RIK...
We fitted a Mal Wood "ACE" billet flywheel & hd clutch to my VT on the weekend and I was very impressed with the quality and the service. The flywheel saved >1kg of weight over the Dual Mass and was obviously well made. We were fitting it to an originally auto engine and the flywheel came with alignment holes for this crank due to not having dowel holes. I was very impressed by this.
The clutch pedal is nice and firm, you can tell the clutch isn't going to slip. No shudder either so far. Haven't driven too much but it's actually got less vibration than the DMF. The DMF may have been very slightly out of alignment though.
The price we got it for is well under the prices mentioned above.
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
