might sound like a strange question, but anyone know a approx cost of having the springs and shocks changed, but using something close to the original berlina spec?
My springs have sagged and the shocks are on their way out, cars done 95000,all hot kms. But i dont wanna sacrifice comfort for performance handling, its my home-tafe-work comfy cruiser, not a race car.
I've only ever seen people lower their commodores, and raise their 4wd's. I assume u can buy stock parts?
Thanks for your thoughts
cewing
Just go to ur local suspension joint & ask for standard springs/shocks for a VY s2 Berlina![]()
The Blue One
Hi mate,
Have a look here:
KYB / Kings Commodore Lowering Packages!
That's lowered packages, but it'll be the same price for stock stuff for your Berlina as it already has roughly 'low' height springs as standard.
Regards,
Greg
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
You'll be able to find a brand new and complete FE2 shock and spring package on eBay for about $400..
-Nick.
aren't they fe1.5 or something? fe2's the sports setup.
thanks for the replies. I think i'll end up going through GSL, as cheap as the fe2 on ebay are, i'll probably want stockies, or something close to it.
Greg, you refered to the berlina as having a 'low' spring height, are u assuming it has FE1.5? or do you mean the bog stock setup(exec) is equivilent to 'low' height springs. I know the VY S2 calais has fe1.5(no cost option), i believe the berlina is the same setup as the exec and acclaim.
as you can proably easily tell i wont be doing the work myself, my friends dad is a panel beater and'll pop em in for me.
Holden are cheap as too for the stockies, they use monroe, i quoted up fe2 for my vy ss and it was cheap as, i was suprised, so yours will be cheap too.
