hey guys,
not sure what its called but its a grill but its where the driving lights fit.. on a holden VY berlina.. has anybody got any ideas on where to get that grill????
cause i wanna put them in mine. but ill need the grill with the lights etc..
Alec
There is one..
a VY Berlina Calais version has one..
Hey Alec
Sorry, sold my VY 2 Berlina lower grille last year for $40. They cost about $110 new from Holden - probably your best bet.
If you are up to it, you can convert your existing Series 1 grille to take the lights. The grille is the same part for Series 1 and 2 Berlina, it just has the holes for the lights cut out and the surrounds then clipped on the Series 2. The mounting holes for the lights should be already there, moulded into your existing grille. I don't know if the light surrounds are available separately, but if they are, it would be cheaper to modify your existing lower grille.
You might be able to remove the grille without having to take off your bumper. It's held in with two screws and a number of strong plastic clips all the way around the grille. However, if you fit the lights, you will have to take the bumper off to reinstall the grille due to very tight space between the bumper and the chassis rails.
