Results 1 to 9 of 9
Thread: Belt Squeal at and above 2500 rpm?
    Vy Berlina
    May 2009
    Yagoona
    Default Belt Squeal at and above 2500 rpm?
    Hello, iv got a 2003 Vy berlina only has 68,000 on the clock i just bought it recently. the last log book service was at 45k. once i bought it i serviced it ( didnt do plugs or leads) i have also installed the Big bore 69mm throttle body and the Type S CAI kit from FIT. runs sweet, altho lately i have noticed a bit of a squeal in the drive belt. and only when the rpm goes to or above 2500rpm. now next weekend i will change the Belt it may fix it altho am considering buying GATES MICRO-V BELT & PULLEY KIT. hope to fix it with just a belt tho. and one other thing. since adding the mods the gears sometimes stick at about 4500 rpm. and a bloke from SAS said it is because the air/petrol ratio is out now so it will need a tune and wants to charge me 1200 for that. what are your thoughts Thanks PPl
    Work your car as much as you want it to work for you.
    2004 VY Executive 2
    Feb 2009
    W.A
    What kind of tune? dyno? my exec II seems to take its time when you max out 2nd gear and change into 3rd. Got quoted 1600 the other week for a dyno tune.. not really worth it if your not gonna force feed it or anything.
    Vy Berlina
    May 2009
    Yagoona
    i think it was for a dyno yeah. something about re-programing the ECU or something. i dont know, is there any other cheaper way to tune up the air-to- fuel ratio?
    Y-Series Senator Signature
    Jan 2006
    Willall Racing
    Vy Berlina
    May 2009
    Yagoona
    i used silicone sprey that i Obtained from work and it has stoped for now. but still want to know about the tune up i need do you guys think its just a dyno ill need to do to make it run smoother.?
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    sounds like BS to me. Try resetting the ECU (unplug the battery for an hour).
    Vy Berlina
    May 2009
    Yagoona
    sweet as man ill give it a go and let you know how i go THANKS heaps
    Vy Berlina
    May 2009
    Yagoona
    it still runs funny but i guess ill have to live with it still goes hard may end up gettin a tune one day
    Vy Berlina
    May 2009
    Yagoona
    A custom program on a vy v6 is $1200 and will fix your shifting problems.
    The reason for your problems is the larger throttle body. They are good for
    making more power but must have the ecu remapped to suit as the computer
    gets mixed messages from the tps and the maf. The expected figures and the
    actual figures don't line up. We can get around this with a custom program.
    this was a reply i got from SAS auto services. anyone do it Much cheaper or is that about right??
  1. VU SS Belt Squeal ??
    By JamesVUSS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-04-2009, 06:30 PM
  2. Squeal - Pulley?
    By leasam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2008, 02:27 PM
  3. Supercharger belt squeal
    By rantin'n'raven in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-06-2008, 08:12 PM
  4. pump squeal. VS
    By XMY308 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-06-2008, 04:24 AM
  5. Brake squeal
    By chromic in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-01-2008, 05:45 PM
