Results 1 to 10 of 10
Thread: Vy V6 Gearbox Noise
    Vy Ute 3.8
    Jun 2005
    Default Vy V6 Gearbox Noise
    Just wondering if anyboby else has had trouble with gearbox noise. Started one morning when down-shifting in traffic. Thought it was a truck next to me. Went straight to the dealer and took a mechanic for a ride. He heard the noise but it wasn't as bad as earlier. I was told they would have to take the box out, but drive it for a couple of days easy til they could book it in. It also started to rattle when idling occasionally. When I took it in, they called me and said they could not hear anything so they didn't pull it out. Since then, I sometimes crunch the gears from 1st to 2nd. This may only happen twice a week. It has also developed another noise and vibration at about 3400rpm. Any ideas guys?
    Marks-VY's Avatar
    Marks-VY is offline I love cars
    VT2 Berlina
    Apr 2005
    Don't expect any help from Holden. Unfortunately I bought a VY S-pack with 5 speed and from day one I have had a whine in first and second gear. Brought it back to where I bought it and they showed me another customer's car with the same mileage and build and it was the same.
    I had the Technical Dept arrange a special meeting and after bringing it for a drive they acknowledged the noise but said it was within specification (although I don't recall any sound measuring equipment......... ).
    They explained the gearbox is manufactured in Mexico and installed as a sealed unit and due to the design of the box etc, it naturally generates the whine. They said I could experiment with different oil grades but that would put my warranty in jeopardy .....
    Anyway, they provided me with a letter to confirm the noise was apparent but within specification, so that if I tried to sell it I could prove it was not a faulty gearbox (my complaint was that I would not be able to sell it as people would think it had been through a hard life).
    I should have bought the s/c auto......
    Regards,
    Mark.
    Vy Ute 3.8
    Jun 2005
    LJ Torana, VL Calais
    Mar 2005
    I've driven plenty of vt to vy commodores with the 5 speed getrag and they all have gearbox whine, its normal.
    VY2 S
    May 2005
    WA
    My manual VY S V6 has been making a weird loud horrid grinding/growling type noise when I let the clutch out- but only when its cold....at night and first thing in morning. Can not get it to make the noise for service mechanic when I take it in ..... so "nothing wrong with it!" Is the only way I could prove fault/noise to have them take it home so it can be started at night or first thing on a cold morning? THEY ARENT HAVING MY CAR AT HOME!
    Someone mentioned it's a bearing and common when cold! BUT I have never heard anyone else with same problem!
    daggett is offline Crazy Tiger
    Commodore S VT Series II M5 & VT II Wags
    Mar 2004
    Goulburn
    I have a VT II S' 5 Speed with the grinding/growling type noise and the whine. I have had the whole cluch assembley go on my 3 times and it's been replaced 4 times. The whine is apparently normal but I finally got them to manage to agree to the problem with the grinding/growling.
    And guess what? After only 12,000k's in the new cluch asselmbley the grinding/growling is back. Oh yay.
    SQUIDS_VX Guest
    Default V6 Gearbox and Clutch
    My 2001 VX S (103000km) has a slight whine from the gearbox, and a clunk when shifting from second to first - but only when it's cold.
    The Clutch feels spongy, Holden dealership says it's okay? but they also tried to sell me a new car? Can anyone tell me the 'real cost' to replace the clutch in this car and/or a good place to take it too, for a second opinion.
    If it does need replacing, it'll be only the second thing i've had to replace - the other being 4 tyres 70000km ago.
    Mar 2004
    Goulburn
    The cluch replacement costs as below:
    Part# GM92116034 - Bearing, CLU PIL x 2 = $4.70
    Part# GM11041011 - Screw x 6 = $1.26
    Part# GM92056275 - Flywheel ASM x 1 = $660.16
    Part# GM92051396 - Plate Driven x 1 = $146.67
    Part# GM92051395 - CVR+Press Plate x 1 = $149.20
    Part# GM92062871 - Bolt Flywheel x 8 = $9.12
    Part# GM92141311 - Bearubg Release x 1 = $98.31
    + Labour of around $262.00
    I also still stuffer this clunk from first to second which is worse when cold also.
    1985 Vk Commodore SL
    Feb 2011
    Bundaberg
    Sorry to revive an old thread
    But I suffer from an insane whine from first and second gear in my storm ute.
    It's louder than my exhaust.
    Is this normal?
    VY S Series 2
    May 2010
    if its a whine i wouldnt worry about it... when it becomes a grinding noise you should be worried
  1. VR Gearbox
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2007, 06:31 PM
  2. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
  3. gearbox noise
    By krisjanik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2006, 08:05 PM
  4. Gearbox for 253/308
    By pro_gmh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-09-2006, 11:25 AM
  5. Replies: 3
    Last Post: 09-09-2005, 11:11 PM
