Results 1 to 10 of 10
Thread: instrument cluster
    binghy is offline Matty 038
    Vy Equipe Series 2
    May 2009
    adelaide
    Angry instrument cluster
    Hi all i tried changing the instrument in my VY Equipe and when i turned the ignition on it bought up an airbag code does anyone now why?
    Cheers Matt
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    What type of cluster did u try installing? You'll have to get it reprogrammed before it gets installed.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    VY S L67
    Nov 2007
    if the cluster was from another vy with different amount of airbags, then the SRS airbag fault will code.
    tech 2 can remove it
    Vy Equipe Series 2
    May 2009
    adelaide
    it was out of a series 1 and mine is a series 2 do u know anyone in adelaide besdies holden the dirty dogs charged me $65 to remove the fault.
    Cheers Matt
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    Normally you have to inform the BCM of the new/secondhand cluster via Tech2 and while there, remove any error codes, ie Airbag, displays reset odometer mismatch in BCM. Also keep in mind that you will not be able to change the odometer reading to the the car original reading as that's hard stored in the cluster it's self and inturn you have an obligation to inform the next buyer (if any) that the cluster is not original. You will find also that your fuel gauge will work in reverse. Due to the difference's in the S1 and S2 clusters.
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by binghy View Post
    Doesn't your fuel gauge read backwards now?
    VY one tonner / gen3 / 6speed
    Jan 2009
    just left of hell
    Quote Originally Posted by caaf View Post
    Hmmm...that's interesting, I put a brand new cluster in my VY series 1. Due to the dealer service dept. giving me the wrong part number to order I ended up with a later type cluster. Got dealer to program new cluster in and fuel gauge works although nowhere near accurate. Is it possible they did something with the tech2 to reverse it? Or maybe the new cluster is just a later series 1 type?
    What is so hard about calibrating the fuel gauge too, they have had several goes at it already.
    May 2009
    Melb, Vic
    I guess you may find that you might of picked up a S1 car at or on the change over build date i.e leading onto the S2 family, hence it's working as the loom and sensor are S2?... maybe... Normally nothing hard about it as I think all that happens they select the model and then the tank size. One noticeable difference is the plug it's self, one's green and the other purple I think (I can't really remember to be honest) One thing I do remember is that the difference's between the two are both how they read and the there's difference in resistance.
    Do you find that Distance to Empty and other digital readout to in-accurate? I would think that you should be able to take it back and in-fact get the right cluster.. I guess it's how hard you push as after all you did go through them in purchasing and installation?
    Cheers,
    Dave
    Jan 2009
    just left of hell
    Thanks caaf, I'm kind of over it and probably won't chase it up any further.
    Getting sick of the "yeah drop it off at 7.30 and maybe we'll get to it today" run around.
    I should have mentioned it's a one tonner. Every time i try to order parts there is always some confusion as to what part is correct, even with the VIN. Seems Holdens parts system has "quirks"
    May 2009
    Melb, Vic
    Right oh.. I'm here to help or make you more confused and it looks like I've done both :P (mind it doesn't help that I'm always confused)
    Cheers,
    Dave
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. instrument cluster
    By vy low in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-01-2007, 03:21 AM
  3. Please Help - VT Instrument Cluster
    By Miss-E in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-08-2006, 01:46 AM
  4. new Instrument cluster?
    By Trewman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-02-2005, 04:02 PM
  5. Vt Instrument Cluster
    By Naccas in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-11-2003, 11:06 AM
