Results 1 to 12 of 12
Thread: finished my exec/ss hybrid grille
    03 VY V6 S2
    Oct 2005
    Default finished my exec/ss hybrid grille
    cant believe it turned out this well, ill take some more pics when its installed.
    Attached Thumbnails Attached Thumbnails finished my exec/ss hybrid grille-dscf0283.jpg   finished my exec/ss hybrid grille-dscf0291.jpg   finished my exec/ss hybrid grille-dscf0292.jpg   finished my exec/ss hybrid grille-dscf0293.jpg   finished my exec/ss hybrid grille-dscf0294.jpg
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    im trying to picture what it looked like before u changed it
    Going where no late model stato/caprice has gone before.... GAME ON!!
    VY SV8 HBD---mmmm LS1
    Batting Champ Champion! On The Volley Champion! Shootin Hoops Champion! Simon Champion!
    Dec 2005
    Western Suburbs
    03 VY V6 S2
    Oct 2005
    Its a VY Exec chev grille with the silver chev bar removed and the bar from a VY ss grille implanted. See below
    BTW, i hate chev grilles, especially on V6s
    Attached Thumbnails Attached Thumbnails finished my exec/ss hybrid grille-db34_1.jpg   finished my exec/ss hybrid grille-0beb_1.jpg
    Dec 2005
    Western Suburbs
    walesy's Avatar
    Jun 2005
    Perth SOR
    ohh ok i see now yeah that does look better.. well done
    03 VY V6 S2
    Oct 2005
    VY Executive 2003
    Sep 2007
    Hey Mate.
    Could you give me a run down on the whole process. I am interested in doing this myself.
    How did you get the SS middle bar so flush with the chev grille at the sides???
    03 VY V6 S2
    Oct 2005
    It went like this
    bought both grilles, the silver chev bar just unclips and theres a plastic bar underneath it.
    with the ss grille, theres a groove along the top edge top the bar and around the edge of the badge i used a hacksaw/bandsaw/dremel to cut it.
    The actual ss bar ends up longer than the chev bar, so all thats needed is to trim each end of the ss bar on the same angle as the chev surround. but leave it a little bit longer. measure it about 30 times before you cut it and dont trim too much off at a time. it probably wont fit perfectly, but its hard to see in the photos.
    I posted a photo of the remnants of the ss grille..
    the way its attached together, i superglued 6 4mm nuts to the inside of the ss bar then i drilled 6 holes in the chev grille surround in the corresponding spots. then i wound 6 nuts onto 6 screws, put some loctite on the ends of the screws and screwed them into the nuts on the ss bar though the holes on the chev surround, just enough so they grabbed. waited for the loctite to set then i wound the other nut on each screw down so it pulled the ss bar down tight, then i loctited those nuts. solid.
    Then i superglued and epoxied the bottom of the holden badge to the new surround, just clamped it together while it dried,
    the top of the holden badge just touches the top of the new surround, so i glued it there too.
    there is a difference in colour between the grilles, so i painted it with vht vinyl dye.
    Attached Thumbnails Attached Thumbnails finished my exec/ss hybrid grille-dsc00156.jpg   finished my exec/ss hybrid grille-dsc00157.jpg
    03 VY V6 S2
    Oct 2005
    ill get some more pics of it installed too because the ones above are a bit shit...
    VY Executive 2003
    Sep 2007
    Excellent. Am looking at getting a chev grille and an ss grille to do it
    cant WAIT
    VY Executive 2003
    Sep 2007
    do you reckon i could use this type of ss grille and cut away the mesh?
  1. anyone modded there vy exec grille???
    By SAV_117 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-02-2009, 09:37 PM
  2. [SA] Wtb vy exec grille
    By SAV_117 in forum Swap / Wanted to Buy / Trade
    Last Post: 10-02-2009, 01:15 PM
  3. Wtb Sa Grille Vy Exec.
    By CANYONERO in forum Swap / Wanted to Buy / Trade
    Last Post: 23-06-2008, 03:39 PM
  4. Antoher take on the VY Exec grille
    By sharebruz in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-03-2007, 05:28 PM
  5. WTB VX Exec/Acclaim Grille Inserts
    By glassjowned in forum Swap / Wanted to Buy / Trade
    Last Post: 16-07-2006, 10:07 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
