Results 1 to 23 of 23
Thread: Cost of Lowering
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    Default Cost of Lowering
    I know this has been covered here and there but what would be the ball park price to lower a VYII to SL (fronts) and SSL (rears) with kingsprings? I am under the assumption that shorter shocks and a 4 point camber kit will be needed as well as fitting. How often will I have to get a camber kit? What are the recurring costs involved?
    Thanks in advance
    A Commodore is a passion. Anything else is just a car
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    $300 to have the springs installed. dont NEED the shorter shocks. Camber kit around $300-$400 installed. Camber kit is simply bushes and they DO wear over time. Maybe in 150,000kms time it could need doing. Seriously just call a few shops and get a proper quote.
    no longer a hoon by association - the commodore is gone
    DUK13Y's Avatar
    Nov 2007
    Sydney, Australia
    Ok thanks mate. I thought with SSL's you needed the shortened shocks. I might look into doing it a bit further down the track. Get the money rolling in a bit first
    Adam_88's Avatar
    Adam_88 is offline soon to be boosted
    red VY Ute
    Nov 2008
    canberra
    i orderd my springs thu super cheap (king springs) and put them in myself its not that har it only cost me $60 for some sprng compressors plus the cost of the sprngs
    DUK13Y's Avatar
    Nov 2007
    Sydney, Australia
    Oh ok. I didn't know they were that cheap.
    How low are your springs?
    Did you need shorter shocks?
    Did you need a camber kit?
    08 SSV M6
    Apr 2008
    Central Coast, NSW
    I run SSLs in rear and SLs in front and I dont run a camber kit or shorter shocks.
    Its fine mate..I plan to put SSSLs and SSLs in and see how she goes!
    Voodoo Blue SSV M6 sedan
    355rwkw
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    If you want it to handle rather then just look good you're best off fitting new shocks (especially if they haven't been replaced before). I think you will need a camber kit if you're coming form FE1. Borderline if you already have FE2.
    daniel555's Avatar
    daniel555 is offline Custom VY Commodore
    VY Executive S2
    Apr 2009
    Vic, Australia
    I run SSL's and SL's. No shocks, Or camber. They dont need them, Aventualy you'll need new shocks, But its not critical.
    VZ AWD One Tonner
    Jul 2006
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    DUK13Y's Avatar
    Nov 2007
    Sydney, Australia
    Thanks for the info guys. I think I might get the camber kit as it's only $100 but can I fit the camber kit myself or do I need someone else to do it?
    daniel555's Avatar
    VY Executive S2
    Apr 2009
    Vic, Australia
    Prob someone pro. You wont need a camber kit untill you get wheels. Stockies will not rub anywhere, And the VY comes with an adjustable camber.
    DUK13Y's Avatar
    Nov 2007
    Sydney, Australia
    I thought the camber kit was to reduce tyre wear as the bad camber would stress on one side of the tyre really badly. For $100 I think it's worth getting the kit; how much would a place charge to fit the kit?
    daniel555's Avatar
    VY Executive S2
    Apr 2009
    Vic, Australia
    I've never heard of that happening. As i said though, VY's have adjustable camber on them, So whoever fits them will adjust them so nothing like that happens.
    VS Commy V6
    Jan 2008
    cars with IRS which yours would have i would deffiently put camber kit on i got superlow kingsprings all round fitted my self using a $30 spring compressor springs cost 100 for front and 120 for rear. If you go superlow or lower i would advise u get shorter shocks after you take a few hard hits they stock ones give up and go the camber kit aswell otherwise you will wreck a good set of tyres on the inner lip in 7000km.Do it once properly!! will cost u more if u take shortcuts in the long term.
  15. #15
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by Beny View Post
    Exactly..... A camber kit costs around 100 bux, thats cheaper then replacing one tyre, so why not?
    Shoterned shocks may not be neccasary, but Id definitly be conisdering it, I know i wouldnt lower a car without them for peace of mind.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
  16. #16
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Plus dumped commodores look like a bloody joke without the camber kits, looks like the back wheels are way overloaded and bending to the point where they're ready to pop right off!! LOL!!!!!!!!
  17. #17
    DUK13Y's Avatar
    Nov 2007
    Sydney, Australia
  18. #18
    daniel555's Avatar
    VY Executive S2
    Apr 2009
    Vic, Australia
    As i said, VY's have adjusting in the rear, Talk to a tyre fitter or something professianly, If the stock camber doesnt have enough adjusting to do what you want, Then buy a camber kit.
    But as i said, Speak to a pro before buying/ordering anything.
  19. #19
    VY II SS
    Sep 2008
    I am getting Lovell SL springs put in my VY II SS tomorrow.
    Not going King Springs, as they are such a harse ride and every car I have ever had or been in that had them, was just crap.
    Costing around $500 fitted for the set, and was told to get the wheel alignment and see if I need a kit. Some cars due to different tightening on different parts of the car, will have different camber etc, so he said wait until it settles down, and if further down the track I need one then so be it.
    I have been told that the fitting for the camber kit is quite expensive. Maybe there is somewhere cheaper, but one kit I got quoted on was $385 for the parts, and $425 labour.
    Seems like a quite expensive excercise, hence why I am not doing it yet.
    How much have people paid for camber kit's and labour because that seems way to much to me.
    Extractors, 100cpi ballistic cats, Sureflo 3.5" medium exhaust, DUS OTR, Oztrack Tune, Phreddy dash, stereo, black windows, Lovell springs, and a good alarm
  20. #20
    03 VY V6 S2
    Oct 2005
    Quote Originally Posted by Skooby View Post
    Ive got Lovells SL on my VY2, done about 15000ks so far on brand new 18" tyres and the rear tyres are wearing normally. I did replace all the shocks though. Maybe its a good idea to replace the rear shocks.
  21. #21
    VY II SS
    Sep 2008
    I ended up getting HRL61SL (Superlow) in the rear, which are a touch heavier duty than the normal ones in the catalogue, and got HFL70XSL (Ultralow) in the front.
    The guy said he could do the catalogue reccomended springs but said it wouldn't sit even. So he reccomended the slightly lower ones in the front which now makes it look perfect.
    Didn't want something that was going to scrape everywhere and look crap, just a nice clean look.
    Very nice ride too, not too harsh and no scrubbing.
  22. #22
    08 SSV M6
    Apr 2008
    Central Coast, NSW
    What has everyone paid for camber kits and installation?
    Cheers.
    355rwkw
  23. #23
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    $200 for camber kit (fulcrum brand), $200 for installation plus wheel alignment. I've noticed so much more traction and stability out of the rear ever since it was installed - that and the rear no longer looks like i'm carrying 600kg everywhere with the wheels bowing in.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
  1. how much would it cost
    By ipsy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-05-2009, 10:49 PM
  2. Lowering cost and opinions please
    By akust0m in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2008, 10:02 AM
  3. Lowering cost
    By Victimiza in forum General
    Last Post: 21-02-2008, 09:57 AM
  4. How much did it cost?
    By destorman in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-08-2005, 05:31 PM
  5. Lowering my VT cost???
    By jeffarido in forum General
    Last Post: 15-03-2005, 04:17 PM
