Results 1 to 22 of 22
Thread: Passenger Seatbelt Light.
    revv_head's Avatar
    revv_head is offline I DRIVE A V6 SS :P
    VY-SII Commodore S
    Mar 2009
    Sydney, NSW
    Default Passenger Seatbelt Light.
    Hey I have a series II S pack and when i shine a torch on the dash, (which is the one pictured in the main banner fyi) i can see a seatbelt picture with the word pass under it. I'm assuming this is a Passenger Seatbelt light but i've never seen it work and dont even think i have sensors in my passenger seat. Why would it be here. Only S packs get this set of gauges and the entire cluster is only used within exec-acclaim/spack levels.
    I own an Commodore, therefore, I own the road
    Oh how i love rear wheel drive
    Junny's Avatar
    Junny is offline purrrrrr
    VUII Maloo + shitty painted vp
    Hangman Champion!
    Jan 2009
    ive been wondering about those lights too.
    and why dont we have those ones that come one when ur door not shut
    Hit the star under this post if it was any help to you =D
    revv_head's Avatar
    VY-SII Commodore S
    Mar 2009
    Sydney, NSW
    yeah thats gay. everyother car i know since about 1990 has those lights.
    04 VZ Exec, HX Kingswood, VB Comm
    Aug 2008
    Sydney Easter Suburbs
    I have it on my VZ as well, i wish there was a way to active it?
    Has anyone actually been able to do this?
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    I imagine to get this light to work, you would need to duplicate the wiring that already exists for the driver's seat belt warning light.
    The driver's side warning light is activated from the seat belt catch. There are two wires running from the loom that also activates the seat belt tensioner in a prang. The wires are black and black with white tracer. They lead into the main wiring harness at the seat wiring connector between the driver's seat and the B pillar. I will have a look at the wiring diagrams to see if I can work out where to from there. Once that's done, it might be a comparitively simple matter of duplicating the wiring up to the warning light.
    (But I bet it's harder than that!) Watch this space.
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Just checked the wiring diag's. The driver's seat alarm is actually only fed by the black./white wire. This feeds directly to the instrument panel light.
    A check of the instrument panel wiring doesn't even show the passenger light as installed but not connected. I'm not familiar with the back of the VY instruments but I know they use multi-pin fixed plugs like the earlier models, so the wiring would have to feed into one of those plugs. You would then need the printed circuit at the back of the instruments to actually feed the passenger warning light. If it does feed that location, then I am assuming that you would need to install the globe, run the wire and Bob's your uncle.
    Of course, I could be very wrong.
    Is anybody familiar with the back of the instrument panel, or have an old one somewhere that they can check the printed circuits?
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Calaber, i'll check the wiring diagrams when i get home from Holden, but i'm fairly sure there's more to it than that. The Series 2 clusters are the ones with the 3 screens right? The series I i know had a different look, but can't remember if the series 2 has 3 screens.
    I thought the seat belt catch patched into either the BCM or the SRS system. I could be wrong though, but when the alarm goes off it also sets off the speaker alarm to alert the driver.
    I think the passenger side alarm was never put into real use because as it sits at the moment it would always alert the driver even if only the driver was in the car. The idea was to put a sensor to work out that there was a passenger on the actual seat, and if there was then alert when there was no seatbelt. But those sensors arn't in the S pack vehicles!
    revv_head's Avatar
    VY-SII Commodore S
    Mar 2009
    Sydney, NSW
    Series 2 had different design but only single window. Only berlina and calais had 3 window. not even ss.
    Nov 2008
    Tullamarine, Vic
    OK, looking through the holden manual it shows that the drivers seat belt warning has voltage from the battery and then the circuit continues on to a "Timer". Thats where the details on that circuit end! It doesn't say anything about the passenger one either. I would think that this timer is actually part of the BCM. So getting the passenger one to work will be quite difficult.
    I even had a look at another manual, and there's absolutly NOTHING in that manual [melbourne warehouse's manual]!
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Hi Alien
    Yeah, it occurred to me that you would need to fit the activating switch into the passenger seat belt mechanism too, and that would be a bitch, unless you could somehow convert a driver's side belt.
    I can't even say I've noticed the blanked off light in my instrument panel (3 window type) but then, I've never looked closely at it.
    It does make you wonder why the provision for the light was provided if it was never used, doesn't it?
    Junny's Avatar
    Hangman Champion!
    Jan 2009
    when i drove out of the driveway without my selt belt on. i relised IT DOESNT COME ON. . . .
    Nov 2008
    Tullamarine, Vic
    Junny, that's because no Holden vehicle was ever equipped with the passenger sensors. Well actually... none of the general public sale vehicles were.
    They have the provisions for it because it was used in a select few vehicles and if people wanted in future they could do it themslves i guess. Even if it is fair pointless.
    Calaber, the reason Holden didn't do it wasn't because of just that it was because there would also need to be a sensor on the seat. And if you put a breifcase on it it would probably set it off. Otherwise the other way of doing it is to make it on a timer to alert if it's not plugged in for the first 30 seconds or so, but if your the sort of person that warms up their vehicle its useless again!
    This feature is probably too much of a hassle to worry about getting working. I definatly wouldn't be doing it.
    Junny's Avatar
    Hangman Champion!
    Jan 2009
    Quote Originally Posted by alien View Post
    1. i meant the drivers seat.
    2. it only starts beeping when u start moving
    Nov 2008
    Tullamarine, Vic
    1. Sorry, didn't know that.
    As for 2, yes i know that, but would be kind of annoying everytime you start moving if there was no passenger there wouldn't it?
  15. #15
    Junny's Avatar
    Hangman Champion!
    Jan 2009
    2. Same as number 1 but, it only starts beeping when u start moving
    lol
  16. #16
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    I agree. Not worth the trouble.
  17. #17
    Junny's Avatar
    Hangman Champion!
    Jan 2009
    oh .... i just remembered my friend had a vz. haha but it was only on the drivers side
  18. #18
    revv_head's Avatar
    VY-SII Commodore S
    Mar 2009
    Sydney, NSW
  19. #19
    Junny's Avatar
    Hangman Champion!
    Jan 2009
    Quote Originally Posted by revv_head View Post
    Junny. Any chance you're drunk?
    nope. i just dont make much sense
  20. #20
    revv_head's Avatar
    VY-SII Commodore S
    Mar 2009
    Sydney, NSW
  21. #21
    Mercedes C200K AMG-Sports
    Mar 2007
    When I used to drive S packs at my old job (I think VZ) the seatbelt beep would come on when I tried to drive without the belt inserted (I'm only talking drivers side, forget passenger).
    My WK Caprice nothing happens if I dont put my seatbelt in. I do prefer it as I cant stand the noise anyways. I'm curious, why would a WK Caprice not have the warning but Commodores do?
    My uncle in Germany (just flew back from there) has the new A-Class Mercedes (yes I told him it was a looserish car in a very nice way... C class would the lowest I'd go) and his car detects even if rear passengers dont have seatbelts. No beep just a message on the dash saying there are people in the back not wearing seatbelts. I do like that idea.
  22. #22
    Junny's Avatar
    Hangman Champion!
    Jan 2009
    Quote Originally Posted by anonymousmoose View Post
    annoying when u just put bags n shit there. it still goes off
  1. Passenger side parker light not working
    By listen_to_slayer in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-08-2008, 11:53 AM
  2. Seatbelt light stays on..
    By miss_vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-02-2008, 05:25 PM
  3. seatbelt light?
    By Troy711 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-08-2006, 10:28 PM
  4. WTB: passenger side tail light VN-VS ute/wagon. ANY CONDITION
    By hakhawk in forum Swap / Wanted to Buy / Trade
    Last Post: 16-04-2006, 11:35 PM
  5. air bag and seatbelt tension light
    By brucef in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-09-2005, 07:11 PM
