Results 1 to 7 of 7
Thread: Slave cylinder leaking, what else $$$$?
    VY one tonner / gen3 / 6speed
    Jan 2009
    just left of hell
    Default Slave cylinder leaking, what else $$$$?
    The one tonner (5.7L) slave cyl. is leaking, while the box is out what else should I look at?
    Car has 170,000 kms, but my son only owned it for last 20,000.
    Have been told these clutches are usually only good for 100,000, so it's either been done before or it's on it's last legs. Have looked into prices for standard clutch $880 plus slave cyl. or Extreme brand HD $1,100 plus slave cyl.
    Considering the engine has a MAFless tune I guess the choice is a no brainer.
    (I can't believe the flywheel has to be replaced with the clutch, every time something seemingly minor happens to this car, I'm broke for months lol)
    What else should I throw money at while box is out, spigot bearing? can the rear main be done with the sump on, or is it like the old 304 with a rope seal?
    Somebody give me some good news I need it.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by red truck View Post
    I gave my clutch a hiding and a half in my VYII and it was still going strong when I sold the car at 135,000 km (had it from new). This included about 70% of the time carrying up to 2.1 ton of weight on the trailer and boat. Do you need to pull the box out to replace a slave cyl??
    If the box is out then yeah do the clutch. None of my Gen III's ever leaked oil - is yours?
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Yes, the rear main seal can be done with the sump still on!
    Once you remove the flywheel and flexplate remove the engine rear cover gasket. This will allow you access to the rear main oil seal in a Gen 3. Then throw on your new oil seal. The rear cover gasket if in good condition can still be used.
    vy ss commodore 5.7ltr
    Jul 2006
    is the master ok? not leaking either? whats the thrust bearing like, iv found from experience best to replace the thrust bearing too, nothing worse than having to take the box out 10,000km's later to replace the thrust bearing when its a 2 min job while box is out.
    Jan 2009
    just left of hell
    Thanks guys. cpbait the slave cylinder is not servicable apparrantly, and the thrust bearing/slave cyl. is all one unit.
    Anyone know if there is a spigot bearing or is it a bush in end of crank?
    Jul 2006
    oh ok, all good yeh i know the ones now, only seen them on some of the alfa romeos at work so thought holden would have them as 2 seperates, all good.
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
    there a spigot bearing and around $90 from memory
    cheers GM
  1. VY clutch slave cylinder (V8)
    By red truck in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-04-2009, 12:15 PM
  2. External HDD, Master/Slave????
    By Wagon_Wheel in forum The Pub
    Last Post: 26-05-2008, 07:41 AM
  3. vs slave cylinder asap
    By mad-mk1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-03-2008, 02:44 PM
  4. POOR CLUTCH - Slave Cylinder, how much?
    By buzurk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2006, 10:55 AM
  5. Leaking Master Brake Cylinder Connecting to Brake Booster Advice help please.
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 02:32 PM
